OEM to aftermarket foglight swap
Old Sep 22, 2004 | 05:59 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I was looking to swap out my OEM foglights with Hella Optiluxs', but I was not sure how extensive the electrical work would be. ANyone done this before? Hella Optilux Kit
Old Sep 24, 2004 | 10:51 PM
nostrixoxide's Avatar
I'm not sure how many wires need to be hooked up. I'm assuming the angel eye portion & the bright lamp can light up individually. If you can get over having the duel lighting feature & just have both of them on at the same time, then all you should have to do is connect the + & - from the stock wiring harness. That way you can still use the factory fog light switch on the steering collum.
-ReLLiK-
Apr 29, 2016 06:25 PM
The Wizard
24
Oct 1, 2015 08:47 PM
catalinvint
Sep 16, 2015 07:48 PM
aminus21
Sep 12, 2015 04:53 PM
JoshG
Sep 5, 2015 10:10 PM
