stock bose stereo with aftermarket subs and amp??
Old Sep 22, 2004 | 11:59 PM
eckohb's Avatar
i've got a 97 se with the bose headunit and everything, and i've got two audiobahn flame q subs with an a8002t amp to match. i want to keep the stock headunit, cuz i like how it looks and everything. what is it that i would all need to keep my stock head unit, and also have major bump in the trunk? also, with this set up, if i got a udp, would i suffer from it?
Old Sep 23, 2004 | 12:18 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Bryan aka cobymoby from Berk Technology sells exactly what you need.
Old Sep 23, 2004 | 12:29 AM
eckohb's Avatar
so would this bypass the amp, and allow me to use rca plugs?
Old Sep 23, 2004 | 06:32 AM
Smaynor2934's Avatar
it hooks into your wiring harness from the headunit, forming true RCA outs, hook these to your amp and you are good to go. use cobymoby to get it, good dealer and a great help to the org
Old Sep 23, 2004 | 11:13 AM
eckohb's Avatar
yeah, i know how to do it and everything. what im asking if this product is the amp bypass and rca adapter all in one?
Old Sep 23, 2004 | 12:02 PM
cobymoby's Avatar
YES, it will.
Old Sep 23, 2004 | 02:10 PM
eckohb's Avatar
fantastic. thats coby, i'll be ordering that product for sure.
Old Sep 23, 2004 | 03:49 PM
2 Da Max's Avatar
or u could get a high low adapter and connect it to the rear speakers its easier than takin out the HU and its only 4 wires, 2 for each speaker.
Old Sep 27, 2004 | 10:36 AM
eckohb's Avatar
well, i just purchased that product coby. thanks for insight all you guys. ill be sure to let you know how my trunk bumps now.
Old Sep 27, 2004 | 08:42 PM
costcowholesale's Avatar
I hope you don't run into my problem or maybe I wired it wrong?? (just spiced the amp remote wire to the PAC)
http://forums.maxima.org/showthread.php?t=341066
Old Sep 28, 2004 | 08:57 AM
GaMax97GLE's Avatar
Originally Posted by cobymoby
YES, it will.
Sent you PM.
Old Sep 28, 2004 | 11:02 AM
cobymoby's Avatar
I had to use a different wire for my remote on my 2000. I'm not sure if it is the same harness for the 4th gen's but I'm pretty sure it is.
Are you using the Green white? Or purple?
SMALL PLUG BREAK DOWN
11 - Ground BLACK
12 – Remote Amp Turn on GREEN/White
13 – Left Rear Negative BLACK/Red **Line Level Signal**
14 – Left Rear Positive BROWN **Line Level Signal**
15 – Right Rear Negative BLACK/White **Line Level Signal**
16 – Right Rear Positive BLUE **Line Level Signal**
LARGE PLUG BREAK DOWN
1 – Left Front Negative BLACK **Line Level Signal**
2 – Left Front Positive WHITE **Line Level Signal**
3 – Right Front Negative RED **Line Level Signal**
4 – Right Front Positive GREEN **Line Level Signal**
5 – Antenna Signal GREEN/White
6 – 12V Constant Yellow
7 – Illumination/Dimmer RED/Yellow
8 – Light Switch RED/White
9 – Ground BLACK
10 – 12V Switched PURPLE
Old Sep 28, 2004 | 11:07 AM
2 Da Max's Avatar
well if u just got the high low adapter, all u had to do was connect 2 wires to each of the rear speakers
Old Sep 28, 2004 | 11:46 AM
Ezekiel 25:17's Avatar
damn I just bought that PAC and I hope I dont have problems but after reading all of this Im just confused about putting it in
Old Sep 28, 2004 | 01:50 PM
2 Da Max's Avatar
just match up the color of the wires
9aj9
Apr 5, 2020 12:11 AM
EdRomo86
Sep 12, 2015 07:49 PM
popdedop
Sep 11, 2015 11:17 AM
Violator
Sep 9, 2015 10:14 AM
