what size for a 5th gen
Old Sep 26, 2004 | 05:19 PM
JdoubleOe703's Avatar
teddibear703
audio newb question
what size are the rear speakers in the 5th gen bose? I have a headunit, so i was wondering if i can just purchase the infiniti kapps and install them straight in or does the bose system do something weird? I heard that each speaker has its own amp? My main question is what do i need to do to install the infiniti speakers into my rear door. I dont plan on adding another amp and plan on using my headunit to supply the power... thanks
Old Sep 26, 2004 | 05:47 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Each speaker does not have it's own amp. The Bose setup has smaller rear speakers than front. I think 5 1/4. You could get a 5 1/4 component system for the rear if you want or cut a 6.5 hole. I have my head unit powering 6.5 Kappa components up front and 6.5 3-way in the rear, mine was a non-Bose system. The head unit powers them adequately. As long as you get a decent aftermarket headunit. Pioneer has good MOSFET circuitry.
Old Sep 26, 2004 | 06:38 PM
teddibear703
so should i get the 6.5 3 ways for the rear? or should i look for the 5 1/4 sized ones? thanks for the help
Old Sep 26, 2004 | 07:03 PM
MannyNJ2k2max's Avatar
you dont have to 'cut a hole' to fit 6.5's in the rear- you simply remove the speakers, cut an mdf spacer ring for the 6.5s and drill them into the sheet metal-
Old Sep 27, 2004 | 01:07 AM
teddibear703
sweet, will do!
MAXSE5SPD
Sep 17, 2022 04:00 AM
RinconI30
Nov 10, 2015 10:55 PM
minsbang
Sep 11, 2015 08:48 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
