Which fuse is this?
Old Oct 5, 2004 | 05:27 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Which fuse is this?
Does anyone know which fuse is for the lights on the instrument cluster? Th lights went out on mine and driving tonight is just well...pretty impossible right now!
Old Oct 5, 2004 | 05:34 PM
2 Da Max's Avatar
check the accessiorie
Old Oct 5, 2004 | 05:39 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
and if that one is not the one looks like your going to be fishing for dead fuses
Old Oct 6, 2004 | 04:54 PM
Ugh, just what I had to do. BUT...I found it
For some godforsaken reason the accessory fuse is wired with the taillamps...why they did not just make a switch called 'ACCESSORY' is beyond me.
Oh, and as far as fishing goes, I checked ALL of the interior fuses, one by one, THEN went to the hood, starting in the lower-right hand corner. What does that mean? That the last f'ing fuse was the one that blew. lol
Well, back to the soldering iron!
Old Oct 7, 2004 | 07:21 PM
adamlee2001GXE's Avatar
that same thing happened to me!!!! I havent had time to check the fuses yet It all started with the odometer not lighting up, then the speedometer, now the speedometer works, but not the tach. I have 56,000 miles on my car.
Old Oct 8, 2004 | 07:53 PM
how do you get the blue cap off the fuses?
Old Oct 9, 2004 | 07:08 AM
Tek-Niq's Avatar
don't get silly the blue cap on the fuses witch are located to the left on the engine don't come off, the whole thing does, those are relays. stay out of there thats big bucs for those.
Old Oct 9, 2004 | 11:06 AM
so if those are the relays, where are the fuses?
Old Oct 26, 2004 | 06:50 PM
steep5's Avatar
New Issue, old post.
It looks like this thread may have died . . . but at any rate, I didn't want to start a new post for a question dealing with dash lights since this one was already here.
My dash lights have recently started to blow the 7.5 minibus fuse that's plugged into the int. illum. slot. I have made no changes to the car, such as new electronics. I replaced the fuse, and everything worked fine for about a day or two. Then I am left in the dark again.
Also, I've noticed that when the dash lights aren't working, the dimmer also does not work. With the fuse in place and working properly, the dimmer works just fine.
I've tried turning on interior lights, my air conditioner, my stereo, cranking the volume (doesn't sound pretty, I have four blown speakers and no cash), rolling the windows up and down, and even blowing the horn. So far, nothing seems to add up.
I'd appreciate any help from someone who has more insight than I, or even better, someone who has experieced the same problem. I'll pay in Kudos.
leatherneck
Sep 30, 2015 09:16 PM
Junebug1701
Sep 25, 2015 01:54 PM
conansriver
Sep 16, 2015 12:17 PM
jwright36
Sep 8, 2015 11:45 AM
