DYnamat vs EDead...which to place a layer of?
Old Nov 8, 2004 | 03:57 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
So I am going to be basically stripping my car down to nothing when I do my new sounds system this spring, and I have been tossing the idea of placing a layer of sound deadening material down when doing so. I have that Dynamat and EDead are both out there, but have not really heard of anyone running with either setup.
So is there anyone out there running with a sounddeadener? How much of an imporvment did you see?
Old Nov 8, 2004 | 08:50 PM
suprropmp's Avatar
i dont have any deadener in my car but I hear it makes a world of a difference...
also, you should check out peel and seal.. I hear it does the same job for a fraction of the price
Old Nov 8, 2004 | 08:53 PM
joebangaa's Avatar
world of a difference.....5th gens are in much more trouble than 4th gen when it comes to rattling, i seriously am skeptical if deadening can help. our cars rattle EVERYWHERE it's soooo annoying
Old Nov 8, 2004 | 09:49 PM
my99maxisnice's Avatar
I have edead, and it did make a noticeable difference for me. I only have it in the front doors, and the mids are much cleaner and more noticeable. Also, the bass is better. 36 bucks shipped and 5 hours of labor later...worth it.
Old Nov 8, 2004 | 10:31 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
DYNAMAT!!! just get the right stuff, xtreme is the only way to go, i had 2 12 for a few months, super rattles....after putting dynamat on the rear deck and in the trunk, the bass is MUCH more solid, it does require a lot of work, but it was worth it. grab a friend and get to work, buy a hot gun from home depot and return after you use it. ahahah
Old Nov 9, 2004 | 06:08 AM
ZIPPIN's Avatar
Mauja He Mauja
i just did the deck with peel and seal. used the heat gun. the difference is night and day. i even stuffed foam towards the window ends,,,works great and it's cheap
Old Nov 9, 2004 | 06:10 AM
Thanks for the replies...I think I am going to use edead since I don't want to spend a fortune on this. I am not going to use any in the trunk since I am not going to be using a subwoofer...I am a heavy-metal kind of guy and all the bass can get in the way of the mids/highs that I am really listening for.
Any other opinions would be great!!!
Old Nov 9, 2004 | 08:55 AM
roman's Avatar
I have Dynamat Extreme in front doors and rear deck. I've had it ever since I installed my system so I can't say if there's a difference or not. I am beginning to notice some rattling so I will add either another layer of dynamat or use Edead V3.
Keep in mind that there are alternatives...I know that there are some "rubber in a can" products which you can use.
I like anything that's liquid because it can get into the nooks and hard to reach places. But if I was doing this from scratch I would first put in a layer of dynamat and then go from there...that's a good base.
Old Nov 10, 2004 | 12:43 PM
aspec0002's Avatar
brown bread, 100 sq ft for like 120 bucks on ebay, its all the same, asphalt based mat, i always use foilbacked, i personally think it does a better job.
Old Nov 10, 2004 | 12:56 PM
loulax07's Avatar
I've used MANY deadeners, which you can see in my sig
I say go with Brown Bread or Second Skin for vertical or hanging surfaces
For areas like the trunk floor or floorpan, you can go with liquid/spray or even less sticky deadeners
You dont need to purchase Dynamat. The above that i mentioned stick just fine.
Click my homepage for pix
aw11power
Oct 10, 2021 04:57 AM
TKHanson
Nov 24, 2018 01:39 AM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Junebug1701
Sep 25, 2015 01:54 PM
