fuse ?
Old Nov 9, 2004 | 08:21 PM
generation3's Avatar
fuse ?
Does the distance from the battery to the fuse matter because I've got my 4 gauge running from the battery to the fuse which is on the firewall? I'll have pics tomorrow.
Old Nov 9, 2004 | 09:33 PM
A32Matt's Avatar
the closer to the battery, the better....IMO
Old Nov 10, 2004 | 03:19 AM
Lystat2k2se
If i remember correctly it should be within 14 or 16 inches to the battery, i always put it about 6" or so
Old Nov 10, 2004 | 07:05 AM
yogi's Avatar
from what i can remebmer it should be within 6 inches of the battery......
Old Nov 10, 2004 | 10:01 AM
what happens if its further than 6 in
Old Nov 10, 2004 | 10:32 AM
bounsmith's Avatar
You will just have a longer section of wire that is not protected if there is a problem.
Old Nov 10, 2004 | 04:06 PM
03SE2HEAR's Avatar
As A32Matt said "the closer, the better". The fuse by the battery is going to protect that long run of wire from the battery on back. If you get t-boned at an intersection and pierce the wire, you will want it to blow that fuse before having a wire fire or shorting out the battery. So be sure you get the fuseholder as close to the battery as possible and make sure you have the right fuse for that length and gauge of wire. If you bought a 4AWG amp kit with a 200A ANL fuse, something tells me that might be a problem if you shorted the wire. You'll want the item that causes the path of least resistance to blow first. That really sucks when it's either your amp of the run of 4AWG that catches fire first.
Old Nov 10, 2004 | 09:03 PM
pics
Here are the pics. I was surprised that Tweeter hid my wiring for me so well. It makes it hard to find it unless your looking hard.[
Did you'll find it? If something happens I'll only fry a few feet of wiring not my amps right?
Old Nov 10, 2004 | 11:37 PM
Tony Fernandes's Avatar
Inline fuses protect the wiring, not the equipment. Your amps should have their own internal fuses for that purpose. Problem is, if your wire shorts in your engine compartment BEFORE the fuse, the wire will melt and/or catch fire...worst case scenario your car turns into a fireball. The closer the fuse is to the battery the less wire is left unprotected (like bounsmith said).
Tony
Old Nov 11, 2004 | 06:54 AM
A32Matt's Avatar
huh? so some RF amps that don't come with their own fuses are ****e outta luck? i always thought that the point of the inline fuse besides the fact to keep an electrical fire from starting was to protect the equipment like every other fuse in the car.
Old Nov 11, 2004 | 07:32 AM
03SE2HEAR's Avatar
Yes, RF did make amplifiers w/o internal fusing for quite a few years...big mistake. The path of least resistance was usually the amp. I guess they depended on people getting a fused distribution block and keeping that somewhere near the amp. The newer amps do have internal fusing...finally. But that doesn't help you out now though.
leatherneck
Sep 30, 2015 09:16 PM
Junebug1701
Sep 25, 2015 01:54 PM
conansriver
Sep 16, 2015 12:17 PM
jwright36
Sep 8, 2015 11:45 AM
