Noise from tape deck on OEM HU.
Old Dec 16, 2004 | 01:24 PM
myiqis180's Avatar
Hello Group:
My stupid radio (OEM) keep making this busted sound. It keeps trying to eject the tape (but there is no tape inside). I tried to put one in and let it kick it out, but it keeps making the sound reguardless.
Any one has/had this problem? Any way to fix it with out unmounting the HU?
I was even thinking about jamming something in there, even if I don't use the tape (which I don't normally). Maybe resetting it? (by disconnecting the battery)
thanks for any info.
Old Dec 16, 2004 | 01:26 PM
|Bijan|'s Avatar
UCF Lexus
http://carstereohelp.com/stereoremovalNisMax2.htm
tape player is probly fried...it's 2005 almost, time for CDs and MP3s man!
Old Dec 16, 2004 | 01:44 PM
myiqis180's Avatar
hahahah, yeah, what am I doing listening to tapes, hahah.
I have a 10 Disk, MP3 CD changer, that's why I wanted to jam the tape, I just don't want to hear that loud clanking noise it makes trying to eject a tape that it's not there. Maybe I'll stuff it with foam.
Maybe I'll just get at new HU since it cost about $200 to fix it (according to that site).
thanks for the site by the way.
Old Dec 16, 2004 | 01:51 PM
|Bijan|'s Avatar
UCF Lexus
You could disable the tape player though Im sure...theres gota be some wire you can cut to make it dead, if thats what you want...
Old Dec 17, 2004 | 11:19 AM
myiqis180's Avatar
Good idea,
I think I will play around with that. If that doesn't work, I'll may just buy a new After-market radio. (for about $300 instead of paying $275 to fix it)
Old Dec 17, 2004 | 12:04 PM
amixamfan's Avatar
wouldnt you need to replace the speakers with the HU anyways because bose is all intergrated? i thought i saw that somewhere
i bet there is a way to disable the tape deck
Old Dec 17, 2004 | 12:50 PM
MaximaSE96's Avatar
Maxima Owner
no there is soemthign called an interface adapter u can buy or just wire wround the BOSE amps in the pods in the doors and rear shelf
Old Dec 17, 2004 | 01:40 PM
Debade's Avatar
Ive fixed it
I had the same problem in mine, in fact the real problem is that the loader gear is striped. Now what i've done since i don't listen tape anymore i've removed the tape deck section of my HU, the only backdraw of it is that when you start the car with the radio off, it show "tape error" on your HU and if you push the on/off button the message disapear for this ride
This is prety easy to do but i'm a electronic tech by profession so maybe i'm wrong on the "easy" part, and by the way since you are in there you may want to put some heatsink compund to the two transitor that are bolt on to the case so thay wont continue to overheat.
Hope this Help
Dave
Old Jan 16, 2005 | 05:31 PM
myiqis180's Avatar
Hey Dave:
Sorry to bring this post back, but you mentioned that you solved this problem by removing the Tape Deck section of the radio.
I installed some tuff an my car before so i had to take out the whole radio at some point to connect something on the back of it. When I pulled out the radio, I remember it being 1 piece (correct me if I am wrong).
Is the tape section completely separated from the Radio/CD chunk? Is there a way to cut some wire or dissable the tape without removing it? and Finally, do you have any write up and what take out, how to go about it, anything that may need to be re-connected, etc? Thanks, and sorry for all the questions.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
atriuum
Sep 28, 2015 01:19 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
