Question
Old Apr 25, 2001 | 05:47 PM
PrinzII's Avatar
OG and counting...
If I decide to add a second amp (McIntosh or a/d/s) as well as a second JL Audio 12W3, would I have to put a .5 farad capacitor on my system?
Old Apr 25, 2001 | 08:27 PM
jmax
Add together the recommended fuse ratings of all the amps. Next multiply this by 14.4 volts. That is the wattage drawn from the battery at near max power output. For every 1000 watts use 1 farad.
Old Apr 25, 2001 | 08:58 PM
Micah95GLE's Avatar
Add one only if you need one. Amps with a regulated power supply won't benefit from a cap. The Maxima alternator is fairly strong, so you probably won't need a cap with a moderate system. I don't use one.
Old Apr 26, 2001 | 08:48 AM
PrinzII's Avatar
OG and counting...
What's the wattage of your system?
Old Apr 26, 2001 | 04:21 PM
Micah95GLE's Avatar
About 550 watts, and that's with an unregulated power supply in the amp. I've tested the charging system with the stereo and all accessories on, and there is no problem. I could run more wattage without a cap. Plus, a/d/s/ and McIntosh amps have regulated power supplies, so there won't be a benefit to having a cap.
Old Apr 26, 2001 | 08:47 PM
jmax
Unfortunately what you are saying doesn't add up to a good response. A 10 amp alternator may be able to keep your battery charged but even if you had a 300 amp version it wouldn't help with musical peaks. Even the car battery can't supply voltage as quickly as a capacitor. That is why most auto audiophiles install a cap. Follow the 4 steps below.
1) A musical peak hits and may draw 50-5000 watts from the cap.
2) Next the battery recharges the cap.
3) When battery voltage drops below 12.5 volts the voltage regulator signals the alternator to turn on.
4) Then the battery slowly recharges. Even if the alternator were already running it cannot supply a quick surge of power.
Now try this without the cap. The musical peak will hit, less than a second later the current draw is back down to a nominal level of 3-10 amps. The amp never had the current to hit the peak so you missed the impact of the potential CD signal to noise ratio greater than 100dB's.
Old Apr 27, 2001 | 05:23 AM
Micah95GLE's Avatar
Apparently you don't understand how power supplies work and the difference between regulated and unregulated.
Old Apr 27, 2001 | 05:42 AM
PrinzII's Avatar
OG and counting...
That's a good point.
Old Apr 27, 2001 | 06:51 PM
jmax
Apparently you have never pushed an amp hard. Regardless of the regulated power supply, which almost all amps have, when the voltage drops from 14.4 to 12.5 or worse output suffers. And yes, it is true that all good amps have built in capacitors to regulate the power supply. While this may be enough to alleviate a single bass hit it is not enough for a long, loud, low note or several in succession. Nor is it enough to help the rest of the electrical system, such as headlight dimming.
Old Apr 28, 2001 | 01:20 PM
Micah95GLE's Avatar
Well, I'm not into winning SPL contests, so I don't go around pushing my amp to 100% all the time. The best way to set a system up is to have more power than you're gonna use, so that there is plenty of headroom in the system, which keeps the amp cooler and the distortion down. Also, even with my system up as loud as I care to listen to it (which is very loud... I'm a professional musician) with the engine on (~14.4v), the volume and intensity don't decrease a bit when I shut the engine off, and the amp gets ~12.5v. So you can buy all the extra parts and components that all of the competitors have, but much of it is useless for moderate systems in daily drivers. You won't find anybody that's heard my system say that it lacks bass, and that's with the sub level at 40% all the time.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
