keeping the box in place...
Old Feb 14, 2005 | 02:10 PM
monty95's Avatar
hey whats up guys...Ok...my sub box always moves around the trunk. I need a good way to keep it in place. I dont really drive that crazy. Anybody have any suggestions? Thanks...
Old Feb 14, 2005 | 02:36 PM
slickrick's Avatar
L brackets attached to a 1/2" piece of plywood mounted under the carpet.
Old Feb 14, 2005 | 02:41 PM
sachmo12345
i used a bungie cord and it works perfectly look at the top farthest towards the seat and there are holes there and i just put the hooks in there
Old Feb 14, 2005 | 03:05 PM
monty95's Avatar
yeah, I like that bungie cord idea. I thought about L screws, but didnt know if i should just drill a hole in the trunk. I also thought about getting like a 2 X 4 and just...wedging it between the Sub and the trunk. thanks for the ideas.
Old Feb 14, 2005 | 03:54 PM
machinehead's Avatar
monkey poo
Old Feb 14, 2005 | 04:10 PM
WaarrEagle's Avatar
Here is mine:
Old Feb 14, 2005 | 04:28 PM
AscendantMax's Avatar
heavy duty bungee cord for the time being...
Old Feb 14, 2005 | 04:43 PM
2 Da Max's Avatar
my dam box is allover the place too, i dont want to use the plywood because im afraid i wont be able to get to the spare
Old Feb 14, 2005 | 05:00 PM
you can try to hinge it, so a portion can still lift up to get to the spare.
Old Feb 14, 2005 | 05:26 PM
2 Da Max's Avatar
hinge it huh...... what about half of it? like is it possible to just put plywood only on the back half of the trunk? can i drill into the metal?
Old Feb 14, 2005 | 05:43 PM
slickrick's Avatar
yes..but just drill into the plywood, thats why its there.
Old Feb 14, 2005 | 07:01 PM
WaarrEagle's Avatar
I am not using the stock spare tire cover. I bought some particle board and cut it to fit. It is much more sturdy. With the setup I have you can easily unhook the box and lift it over the brackets to remove it. Then you can get to the particle board that covers the spare and lift it out. My brackets are mounted so that the carpet is secured to the spare cover but you could cut holes for the brackets if you thought this would be a problem. Having the particle board/plywood vs. the stock spare cover makes no difference when getting to the spare tire. Its the actual sub box that will give you trouble and it will be there no matter what is under it.
Old Feb 14, 2005 | 07:22 PM
sachmo12345
my way is perfect just go and look at what i was talking about
Old Feb 14, 2005 | 07:33 PM
WaarrEagle's Avatar
I also tried the bungie cord method. The problem was that I only had 2 short ones. I connected them together but the connectors happened to meet in the front of the box. One day they rode up so that they were in front of the sub and that is why I have so many nice dents in the cone.
So if you do try the bungie cord method, make sure nothing hard gets in front of the sub.
Old Feb 15, 2005 | 10:23 AM
bolting the box down nice and snug increases the transfer function effect
Old Feb 15, 2005 | 12:13 PM
slickrick's Avatar
^^^ care to explain that further?
Old Feb 15, 2005 | 12:23 PM
Assassinroon's Avatar
so these l shaped screws your saying you have to buy 2 piecs of wood and put it under the carpet where do you mout the wood to the metal underneath the carpet??? wouldnt ur box be levitating then
Old Feb 15, 2005 | 12:26 PM
slickrick's Avatar
they are l brackets... l shaped pieces of metal that are like $3 from walmart for a pack of 4. you screw the top part of it into the box..and the bottom into the floor where i reccomend putting plywood or some sort of 1/2" wood to screw into.
Old Feb 15, 2005 | 02:14 PM
sachmo12345
just gotta find the right length of cord and you are set
Old Feb 15, 2005 | 02:31 PM
sercuring it to the car makes it louder some times
Old Feb 15, 2005 | 02:49 PM
how so? please explain...sounds interesting.
Old Feb 15, 2005 | 03:46 PM
slickrick's Avatar
if you are trying to say by having it stable it will be louder, i guess you are referring to a sub box being sturdy and not flexing. flexing= loss in spl. however i feel with a nice box whether its tied down or not it should be fine.
Old Feb 15, 2005 | 05:09 PM
WaarrEagle's Avatar
I would not secure the box to the brackets - that would make for too much trouble if you have to remove it. Just sit it inside the L brackets. As for securing the piece of wood underneath, I just used the plastic pieces that keep the stock piece from moving around and put them on my new particle board piece.
Old Feb 15, 2005 | 05:11 PM
slickrick's Avatar
you remove 2 screws???
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
