need help wiring my sub...
Old Feb 27, 2005 | 10:30 PM
nycspudz03's Avatar
I have an audiobahn aw1200q which specs are as follows:
dual 4ohm voice coil 700 watts rms; 1400 watts peak
and I have a mtx 801d amp which specs are as follows
400 watts x 1 at 4 ohms
800 watts x 1 at 2 ohms
I wanna wanna wire them up without blowing them. I know its 800 watts rms if i wire it at 2ohms so is it a good idea.
can someone tell me how to wire it up please? I need a diagram or something
thanks in advance fellas...
Old Feb 27, 2005 | 11:40 PM
kpr10is's Avatar
-kevin
Old Feb 28, 2005 | 12:30 AM
nycspudz03's Avatar
thanks man...
Old Feb 28, 2005 | 03:53 PM
nycspudz03's Avatar
I wired the sub and its not hittin at all
Old Feb 28, 2005 | 03:54 PM
AscendantMax's Avatar
wired correctly? gains set ok?
Old Feb 28, 2005 | 04:31 PM
nycspudz03's Avatar
yea...i wired it just like the diagram above, and its not hitting like i expected to. I thought that it would pound because I was feeding it more power than it says. Do you guys think that if I purchase a bass **** help?
Old Feb 28, 2005 | 04:50 PM
not sure, it should still get loud. however, loud is is purely based on the person hearing it.
did you try wiring it in a series? (you'll get less power, but curious if you'll hear any difference in output)
Old Feb 28, 2005 | 05:10 PM
slickrick's Avatar
what size box and type?
Old Feb 28, 2005 | 05:28 PM
nycspudz03's Avatar
ported box. I bought it from ebay...I really wanted something that wouldnt take up a lot of space.i think its like 1.86 ft^3
nycspudz03's Avatar
anyone think the bass kno will help any??
Old Feb 28, 2005 | 05:40 PM
InfinitiStyle's Avatar
A bass **** may help, but only if applicable to the amp.
Mess around with the gains, and the bass/sub settings in your deck. (if your running a line out convertor, turn up the signal strength if possible)
Old Feb 28, 2005 | 06:14 PM
2 Da Max's Avatar
check your gains, and a bass **** is not a volume control, just set the gains and you should be good to go
Old Feb 28, 2005 | 07:38 PM
RicoSuave98's Avatar
check the wires on the sub itself- this happened to me once- had the pos and neg bassackwards
Old Mar 2, 2005 | 05:49 AM
JamesNH's Avatar
i would check the frequency **** on the amp too if its too low then its not going to pick up close to 0 frequencies
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
