How to Keep Sub Box From Moving???
Old Mar 27, 2005 | 04:04 PM
LLZuB's Avatar
Hey guys,
well i just installed a 10 inch and my box keeps moving around... whats a good way of mournting it??? i wanna still be able to take it out once ina while since i use my trunk so i dont want to screw it down or anything....
anyone ever use velcro strips?? was thinkin about that but not sure
please lemme know how all you guys have kept yours from moving around yet kept it easy to remove when needed
Thanks!
Z
Old Mar 27, 2005 | 04:11 PM
mtnbikeair's Avatar
maybe you could build like a little lip in your car. Like run a piece of wood, or metal or something across the length of your trunk, and screw that into the trunk and then your subs will rest firmly up against that and not move, but you can still take them out because the subs arent mounted.
Old Mar 27, 2005 | 04:14 PM
THX's Avatar
THX
Hallelujah
I just cut out a sheet of MDF (cheap at Home Depot) to my trunk. Put the carpet over it, and you can use angle brackets to secure the sub in place. You don't have to screw the brackets into the sub box, just have one on each side.
Old Mar 27, 2005 | 04:30 PM
AscendantMax's Avatar
bungee cords...it's keeping my big **** box in place. kind of a cheap fix but it works.
Old Mar 27, 2005 | 04:40 PM
filtor1's Avatar
I used L brackets and sheetmetal screws. Doesn't move at all. I have 2 Diamond Audio TDX 12" in a 4.&&cf ported enclosure. Very heavy. I am however going to replace the stock floor mat and use 3/4" MDF cut to fit so I don't tear up the undercarrage with the screws. Either way depending on budget and how deep you want to go into the project.
Old Mar 27, 2005 | 05:01 PM
minsbang's Avatar
That's a great idea! I'm definetely going that route.
Old Apr 2, 2005 | 06:24 PM
WickedMax3's Avatar
email me and ill show you some pics of how i got my box tied up! its pretty simple i think i have the bungee cords. i got two 12s.
Old Apr 2, 2005 | 07:41 PM
WaarrEagle's Avatar
Same here:
Old Apr 2, 2005 | 09:56 PM
THX's Avatar
THX
Hallelujah
^^^Looks good. Are your amps hiding?
Old Apr 2, 2005 | 10:10 PM
what happen to that poor sub? looks like it was hitting something while moving.
Old Apr 3, 2005 | 08:32 PM
WaarrEagle's Avatar
If you look closely you can see my amp to the left of the box mounted on the back of the back seat. The dents on my sub came from a bungy cord that rode up when the sub was on. I didn't have one long enough so I had two of them together and they connected right at the front of the box. When they rode up the sub hit the two hooks. It still sounds good so I don't worry about it.
Old Apr 4, 2005 | 09:00 PM
Gramdacious's Avatar
Did you have to cut the MDF in two pieces to get it into the trunk? I love that idea, I'm gonna do it next.
Old Apr 5, 2005 | 07:24 AM
WaarrEagle's Avatar
Nope - it fits easily as one piece. Just use the old cardboard piece as a template. Its real easy to remove the box too as you can just lift it off the brackets.
Old Apr 12, 2005 | 10:49 PM
RicoSuave98's Avatar
any more ideas.. not really feelin any of these. i really don't want to drill my box
Old Apr 12, 2005 | 11:53 PM
Slider's Avatar
There's this rubber lining thing that's pretty grippy. I just can't remember the name of it. It came with when I bought my TV so it wouldn't slide off if anyone decided to try to move it or something.
Old Apr 13, 2005 | 07:40 AM
Last weekend I made a "false floor" in my trunk and lined it with carpet. Now There is virtually no rattles in my trunk (except my trunk lid from the bass) and my box doesn't move an inch even in hard cornering. The carpet on carpet approach works well, no sliding at all.
Old Apr 14, 2005 | 09:42 AM
AlexI30's Avatar
Has anyone her used velcro?
That was the route i was interested in, im sure it would be strong enough, just wondering how the adhesive would hold on the carpet?
Old Apr 14, 2005 | 01:13 PM
machinehead's Avatar
velcroing to the carpet does nothing, itll just push the carpet around with the box. just bolt that biatch down. or get a trunk monkey.
Old Apr 14, 2005 | 04:53 PM
WickedMax3's Avatar
i tied mine with bungee cords
Old Apr 16, 2005 | 04:22 PM
snowangel82's Avatar
i put a thin piece of wood in my trunk and screwed the box down to that.
Old Apr 17, 2005 | 06:08 PM
generation3's Avatar
You could duct tape it to something. Or if you want put in a wall and drill some holes through the wall and a little into the box to hold it.
Old Apr 18, 2005 | 05:49 AM
WillMax95's Avatar
anyone got pictures of the bungee cord thing
Old Apr 18, 2005 | 12:25 PM
so this is what i came up with....
its just a piece of particle board. i have 2 screws on either side of the brace in the back of the car. i just drilled them into the board covering the spare. it seems to work pretty well and looks better than a plain wood brace
Old Apr 18, 2005 | 01:14 PM
thephatOne's Avatar
haha nice, isnt there a thing called carpet glue or something? I saw it at home depot once, suppose to stick carpet to carpet, anyhow, if I were to use a false floor I would have two piece, the further piece having a inch high wood going all the way across securing the box and the front piece so you can access your spare tire
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Sep 27, 2015 08:37 AM
