Question about capacitors
Old Apr 4, 2005 | 09:09 PM
Gramdacious's Avatar
I just ordered an Audiobahn 1 farad capacitor. I've got three amps running about 900 watts. I have a big fuse holder under the hood, so do I need more fuses after the capacitor? I have a distribution block right now but it isn't fused. Do I need another individually fused distribution block after the cap in addition the the one near the battery?Any help is appreciated.
Old Apr 4, 2005 | 09:30 PM
2 Da Max's Avatar
no you dont need fuses after the cap, just one main fuse atleast 12ft close to the battery. btw a cap is not necessary if you have a thick awg of wire, it just put more stress on the altenator because its just an acc.
btw i have 3 caps for sale pm me
Old Apr 4, 2005 | 10:02 PM
Conrad283's Avatar
I need a truck
I had two huge eclipse amps along with 0ga wire. Never needed a cap.
Old Apr 4, 2005 | 10:04 PM
Pearl96Max's Avatar
I tend to get a bit irritable
I have 4 fairly large Arc amps, I have better things to do with my money then waste on useless products like a cap.
Save your money and invest it into something more useful.
--Don
Old Apr 4, 2005 | 10:09 PM
slickrick's Avatar
don you running eclipse ti's now??
Old Apr 4, 2005 | 10:26 PM
Pearl96Max's Avatar
Yes sir
Old Apr 5, 2005 | 03:29 PM
Conrad283's Avatar
I need a truck
Originally Posted by Pearl96Max
Yes sir
Just one four letter word describes it all. L-O-U-D.
Old Apr 6, 2005 | 07:19 AM
I'm not running wire that big. All I know is that my lights are dimming and I 'd prefer those amps to run off the cap not the battery.
Old Apr 6, 2005 | 07:26 AM
filtor1's Avatar
The cap will not help your dimming lights. An additional battery will.
Old Apr 6, 2005 | 07:38 AM
Pearl96Max's Avatar
Prefer to run them off the cap? That is not an option, it will still be run off of the battery when the car isnt running and from the alt when it is. You cant just run them off the cap, it will last about 5 minutes.
Best bet is to upgrade your alt. Adding a second battery will cause more strain on your stock alt....Chris you know this !
Old Apr 6, 2005 | 07:49 AM
maxgtr2000's Avatar
KH3 by popular demand
You can try adding a yellow top but get a battery isolator, wire the amps directly to the yellow top. You can find an isolator for about $20+ shipping on eBay. Put the turn on wire for the isolator (the isolator is only a glorified relay) on a switch and only switch it on like when you hit the highway or something to keep it charged or charge when you need too, that way your charging system is not always stressed by always charging 2 batteries. Here is a link to one by the way.
http://cgi.ebay.com/ws/eBayISAPI.dll...765525450&rd=1
You only need a high amperage isolator if you'll be running more than 1 extra battery.
Old Apr 6, 2005 | 07:54 AM
kcidmil's Avatar
Ok, maybe it's the lack of sleep that's making me read this all wrong... but are you running 3 amps for the total power of around 900 watts? If that's the case, a new amp would be in order, not a Cap.
Or if you got 3 amps running 900 watts each... maybe you should upgrade to something new. Memphis has their MOJO amp, 2000 watts. Requires 13.8 volts to run it, so you'd need an upgraded alt to handle the load. Or Hifonics has their new Maxximus. 10KW
Old Apr 6, 2005 | 10:34 AM
2 Da Max's Avatar
lol my friends think my cap is nos
Old Apr 6, 2005 | 11:11 AM
RicoSuave98's Avatar
my buddy got a cap online, it was 2.0 fared, i think, and it stopped his lights from blinking. i was thinking of gettin one, but maybe i'll just get a yellow top- kinda expensive though. or should i just upgrade my wiring? i got 4 ga now
Old Apr 6, 2005 | 10:01 PM
In due time,
I'm getting rid of one of my amps and will run all door speakers off my 4channel at 2ohms, instead of two amps to doors. Then I'm waiting for my Phoenix gold mono, 500 watts at 2 ohms. This alone shoud help relieve some stress hopefully. If I could afford to buy a 10K watt amp I'd be driving an NSX right now
Old Apr 7, 2005 | 06:31 AM
kcidmil's Avatar
In due time,
Memphis has their Memphis Belle series. They're a 5 channel amp, they offer a 600 watt or the 1300 watt. Saves having to get seperate amps. But some people like having seperate ones...
Old Apr 7, 2005 | 07:00 AM
filtor1's Avatar
Best bet is to upgrade your alt. Adding a second battery will cause more strain on your stock alt....Chris you know this ! [/QUOTE]
I know I know. I need to upgrade mine badly. My lights don't dim at all though.
Old Apr 7, 2005 | 07:12 AM
Sky_99's Avatar
Check out this link.
It doesn't get good until Geolemon's and Nasty Torto's replies.
In my experiences caps do help, as stated. Unless your power needs are WELL over what your stock alt/battery can supply.
Old Apr 7, 2005 | 07:18 AM
MannyNJ2k2max's Avatar
actually more like a 6 letter word... I-N-S-A-N-E
Old Apr 7, 2005 | 07:22 AM
Gramdacious- caps are useless, but who am I to tell you...
To answer your question- you should use the cap AS YOUR DISTRIBUTION block and have your amps feeding off of it- the cap itself getting power directly from battery not a distroblock-your main fuse is more than adequate
Old Apr 7, 2005 | 07:56 AM
Thats a good idea. In fact, I was gonna do that. I have a cheesy 1 into 2 distribution block, but now I will just run the amps power supply directly from the cap. I am using the cap to cushion my electrical system. Indeed I am not using a cap to "stiffen" my amps, bass, or for general loudness. Thanks.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
