Firewall Question
Old Apr 8, 2005 | 04:14 PM
MadMax315's Avatar
Firewall Question
Is there anywhere in the firewall that i can run the amp power wire through because I would like to avoid drilling anywhere? My cars year is a 95. A picture of the hole would help too if anyone had one.
Old Apr 8, 2005 | 06:13 PM
JDogg96's Avatar
I just did this recently, but I don't have a picture. I jacked up the drivers side and took off the wheel, then the plastic wheelwell. After you remove the wheelwell you'll see a cable running from the engine bay, into the wheelwell, then through a gromet into the passanger compartment. cut an X in this gromet (being careful not to slice anything inportant) and poke the cable through. There is a hole behind the strut tower that you can run the other end of the cable through to get it into the engine bay. I hope that explanation is clear enough, just PM me if you have any questions.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
