are these RF subs good?
Old Apr 9, 2005 | 09:08 PM
josehernandez94's Avatar
These Rockford-Fosgate subs seem to be a pretty good price. Are they pretty good? I don't need anything competition-level, just something that'll thump pretty nice.
Let me know what you think:
http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
Old Apr 9, 2005 | 09:11 PM
Or how about these JL audio subs? I've heard really good things about them... seems like $285 is a pretty good price for them.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
Please let me know what you think.
Old Apr 9, 2005 | 09:27 PM
And does anyone have any suggestions for a good amp for these?
Old Apr 9, 2005 | 10:11 PM
blakstarz's Avatar
Those are very good subs.....you can't go wrong with Rockford. Their subs are raw power. I have the Stage 2 RF series subs in my other car and they are vicious......I say go with a Rockford 2 channel amp: http://www.bestbuy.com/site/olspage....=1099389702599
Old Apr 9, 2005 | 11:07 PM
AscendantMax's Avatar
yeah, feed them enough power and they'll hit pretty hard. i still personally like the older model RFs are better than the new ones. the HX2's was their higher end line of subs.
Old Apr 10, 2005 | 12:11 AM
kcidmil's Avatar
I run Punch Z's that are 3 years old... and they're decent speakers for being RF low end. And I've played around with some of their stage 2. They sound really good... but I'm a Memphis fan.
Old Apr 10, 2005 | 03:31 PM
Thanks for the advice. I just have a question. It says the subs handle 500W RMS, but the amps only put out 400W RMS. Wouldn't the subs be underpowered?
Old Apr 10, 2005 | 04:58 PM
filtor1's Avatar
Neg. 500 watts is an average # for a daily driven non competition system. A bit more or a bit less is not a big deal. If you fed it 100 watts, you will run into underpowering and lots of distortion.
Old Apr 10, 2005 | 05:02 PM
Trevmister1610's Avatar
if o look on the rf web site i think they give a range at how much power they should be given, its like 300-500 but im not positive
Old Apr 10, 2005 | 05:07 PM
filtor1's Avatar
OK, I just took a closer look at that amp. It will not be enough. 300watts at 4 ohm. If you want to find a more efficient pair of subs, that amp will do 150watts X2 at 2ohms. Those RF and JL subs will need more that 150 per sub.
Old Apr 10, 2005 | 06:09 PM
Hey man,
Thanks for the info. Is there an amp you'd recommend that would adequately power those subs? All this ohm stuff confuses me so I'm not exactly sure how to match an amp to subs. I just figured that 500W RMS RF subs would be good and want an amp that will definitely power them well, so if you know of one, please let me know.
Old Apr 10, 2005 | 06:29 PM
Would the RF bd1000 be sufficient?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old Apr 10, 2005 | 06:31 PM
One other question: Will I need a capacitor for a system of this wattage?
Old Apr 10, 2005 | 06:39 PM
2 Da Max's Avatar
no a cap is NOT neccessary in almost any system. just run some thick guage power wire, 4 or lower
Old Apr 10, 2005 | 06:42 PM
Cool, thanks. For the old system I got in there now, I have 8 gauge. I guess I'll just get some 4 gauge and a distributor.
Old Apr 10, 2005 | 10:32 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Tell us your budget and Im sure we can put together a nice set of subs with a matching amp.
Old Apr 11, 2005 | 12:25 AM
kcidmil's Avatar
Don't forget to let us know what type of music you listen to. This helps out when showing subs. Certain subs run better in Vented or Sealed boxes.
Old Apr 11, 2005 | 06:52 AM
Budget for subs, amp, and box is probably $500-600. I listen to a lot of rap, but also some rock too. I think I'd like to get 2 12s if I could get pretty decent ones, otherwise 2 10s. Let me know what y'all think. Thanks.
Old Apr 11, 2005 | 07:48 AM
filtor1's Avatar
Contact Don(Pearl96Max) for suggestions. And yes the BD1000.1 would be sufficient. The .1 on the end means it is 1ohm stable. For this amp to work to it's capacity, you will need to match your voice coil configuration to meet the 1ohm load. hear is a small site I refer to when asked these type of questions.
http://elliottelectronics.com/Spkwiringset.htm
Old Apr 11, 2005 | 08:08 AM
kcidmil's Avatar
Hmm, one 12" Memphis M-Class, in a vented box and 500 D amp would run you about $550. And will give you a pounding.
Vented will work great with your rap music. And the combination of the M-Class and 500 D amp will keep your rock sounding clear. That's my recomendation. But hey, I'm the "Resident Memphis Nut"...
Old Apr 11, 2005 | 05:28 PM
Pardon the ignorance, but what's a vented box? Also, would it be that much more expensive to get two of the M-Class subs? Can that one 500 D amp power two?
Old Apr 11, 2005 | 08:34 PM
Pearl96Max's Avatar
Umm Chris, hate to do this to ya buddy, but thats incorrect. The ".1,.2,.4,etc" refers to the channels. Although that amp may claim to be stable at 1 Ohm, its sheer coincidence. Otherwise that would mean the 800.4 and 500.4 are only stable to 4Ohm?
Old Apr 12, 2005 | 01:15 AM
kcidmil's Avatar
Already gave you a PM about the subs and amp. A vented box is almost the same as a ported. I refer to ported as having round openings, vented having the square.
The box in my truck was designed specifically for the Memphis subs. It's a big box as you can see. The M-Class works well in smaller boxes, my box was built in mind to hold a M3.
If the picture doesn't work, click on "Cardomain Site" on my signature.
Old Apr 12, 2005 | 02:32 PM
filtor1's Avatar
I need to get on the ball. I honestly thought that is what it stood for. I didn't think to reference that theory with other amps. I think I will stop posting for a while. My brain must be tuning into mush.
Thanks for the correction. I learn from you guys everyday.
Old Apr 12, 2005 | 04:55 PM
slickrick's Avatar
dont stop posting...***** it up like me. "learning is fundamental". i know ive heard that phase 100x when i was younger but not sure where.
Old Apr 12, 2005 | 07:22 PM
2 Da Max's Avatar
yes never stop posting, i just kept posting and it made me learn a whole lot
Old Apr 12, 2005 | 08:34 PM
Pearl96Max's Avatar
Just remind me to smack you for that one when I see ya Friday.
Old Apr 12, 2005 | 08:38 PM
slickrick's Avatar
damn chris you all are going up this weekend? maybe me and kevin should send up a care package.
Old Apr 12, 2005 | 08:40 PM
Pearl96Max's Avatar
Just him and Jeremey, if I work fast Ill have em outta here by Friday night. Then I can run around the house Nekkid again
Old Apr 12, 2005 | 08:43 PM
kpr10is's Avatar
Chris...see what school does? my brain is mush a lot too...
When will you start the install?...what exactly are you doing in it and how long will it take, mr. 'i can do a 791 in 1.5hrs'
Old Apr 12, 2005 | 08:45 PM
Pearl96Max's Avatar
Eh a few things, Im not sure if Jeremy wants that much info out there, so Ill keep quiet.
Dont hate, your still young, youll get there sometime. And actually just did one yesterday. 2005 Accord 1hr 47mins on the nose.
Old Apr 12, 2005 | 08:48 PM
kpr10is's Avatar
damn i figured you might not spill the info...
we officially have python in stock now at circuit city so i might be able to start installing some good stuff instead of the code alarms
slickrick's Avatar
what, is jeremy getting funky pups in a wall?
Old Apr 13, 2005 | 03:59 AM
filtor1's Avatar
Oh snap. It took us three days. Newb installers sheesh. That is crazy fast .
Old Apr 13, 2005 | 04:01 AM
filtor1's Avatar
Like soo...... I can't wait to learn from Master Don Pearl 96 Max Sir Stereo this weekend.
Old Apr 13, 2005 | 04:02 AM
filtor1's Avatar
Care packages are welcome. Just don't make them too big or heavy. After all, that 05' G doesn't have a ton of room. Especially after my fat a$s gets in.
Old Apr 13, 2005 | 04:06 AM
filtor1's Avatar
Don't let us stop you, I have the digi cam ready.
Old Apr 13, 2005 | 04:09 AM
filtor1's Avatar
There is no good reason for me to be up post whoring soo bad other than sheer excitement. I am going to the car jacking and hostage capital of the country this weekend to do very fun things at Master Don Pearl 96 Max Sir Stereo.
Old Apr 13, 2005 | 04:21 AM
2 Da Max's Avatar
carjacking lol tell me about it you cant even park your car in your drive way no more, im making a room in my house for it.
neways your comming up to Tri state area?
Old Apr 13, 2005 | 06:38 AM
filtor1's Avatar
Yep, I will be there till the install is done.
