Pics of your ground point
Old Apr 11, 2005 | 07:00 PM
sunten1
Can someone post some pics of there ground in the spare tire well cuz i can't figure it out....
Old Apr 11, 2005 | 07:14 PM
Terran's Avatar
I'm going to drill a hole on the side of the spare tire well towards the back of the car. There isn't too much back there to hit (check and double check the spot you pick anyway) and it's pretty close to where my amps will be (one on either side of the trunk). Make sure you grind off the paint around the ring terminal(s). I'm going to use a dremel, but you could probably just use sandpaper. You'll also want to use something to help prevent rust. I think there's something called dielectric grease which prevents corrosion but conducts electricity or maybe silicone spray. Talk to your local autoparts place and see what they'd use to prevent corrosion on battery terminals. Wow, I wrote alot there .
Old Apr 11, 2005 | 09:08 PM
'96MaxGLE's Avatar
Give me ur e-mail and i'll send u some.
Old Apr 12, 2005 | 02:07 PM
sunten1
sunnymistry52@gmail.com
Old Apr 12, 2005 | 07:54 PM
'96MaxGLE's Avatar
I will take some 2morrow and e-mail them 2 ya.
Old Apr 12, 2005 | 08:04 PM
KCMaxima98's Avatar
Couldn't you just lift the carpet back and drill a hole near the wheel well area of the trunk on the left side? I wouldn't think you would hit anything there. Im going to redo mine soon and I considered drilling in the wheel well area. I decided against it cause if you run a 4 gauge or larger wire out of the bottom of the spare tire well you would have to cut a hole in that particle board cover to run the wire through or it will not fit right. And the sub box will probably be sitting on that wire too if it is routed through the center of the trunk.
Old Apr 14, 2005 | 07:44 PM
'96MaxGLE's Avatar
did u ever get my pics?? If so i hope they helped.
Old Apr 14, 2005 | 08:21 PM
TheBigDu's Avatar
I thought I found the best ground point...and then I realized there was some faint noise in my system. It's really faint, but it pisses me off, so I will be moving the ground wire soon. Right now, it's behind the trunk lining, near the shock tower.
I'm pretty sure this is what's causing the noise, because I ran my RCAs and power down opposite sides of the car. I thought sanding the black paint would help, but I just realized that this piece to which I grounded isn't actually part of the body and that there may not be a great connection between it and the body. So, I'll have to find/place a screw somewhere else back there.
Old Apr 14, 2005 | 08:27 PM
slickrick's Avatar
^ just drill a hole in the trunk right below there and use that.
Old Apr 14, 2005 | 08:30 PM
TheBigDu's Avatar
Well, it looks like I'll be chucking the spare and throwing the amps down there this summer when I do the sub install, so I'll definitely be drilling a hole then.
Old Apr 14, 2005 | 11:04 PM
'96MaxGLE's Avatar
here are the 2 pics i sent...figured i would post the links here for everyone else. u'll have to excuse the bare MDF...suede hasn't come n yet. hope this makes everything clearer for all the 4th gens out there.
pktaske
May 6, 2016 07:49 AM
knight_yyz
Nov 6, 2015 02:34 PM
pktaske
Sep 4, 2015 08:40 AM
