5th Gen headunit upgrade
Old Apr 26, 2005 | 09:23 AM
2k2MerlotSE's Avatar
JUVIN's ride
I have been reading for a couple of days now and I am still not sure if I doing the right thing.
I want to install an aftermarket head unit and tweeters and leave in the speakers and sub. Is that a good idea?
I have also read that in time the amps &/or the headunit blows. How true is that?
I wanted to stay away from ripping the car apart, but the more I read the more it seems like I should just upgrade everything, but I'm low on funds.
Has anyone just swap out the head unit and tweets? If so what does it sound like, and would you recommend it?
Thanks for your input.
Old Apr 26, 2005 | 09:38 AM
rustyram02's Avatar
my entire bose sound system blew a few days ago and now getting the whole thing replaced with something of better quality! it was just a matter of time, since i've had that P.O.S. headunit replaced 5 times!
Old Apr 26, 2005 | 12:59 PM
slickrick's Avatar
its so hard to but i cannot stress this enough...do it right the 1st time. this means remove everything BOSE and go aftermarket.
Old Apr 26, 2005 | 01:03 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
If you swap out just the tweets, then you are going to get a better high-frequency response...and that's all. If you are going to do anything, change out the HU and the speakers with a decent coaxial set. Taking the doors off is not hard at all...you can do it!!!
Old Apr 26, 2005 | 02:46 PM
danhaman's Avatar
Be careful just changing out the tweets unless your new head unit has a xover function to keep the low freq's away from them. [I assume you will be bypassing the bose amp, but either way, I bet the signal is only x'd over at the tweets themselves - little in-line capacitors].
dh
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
Maxboy23
Sep 4, 2015 06:04 PM
Lowered_a33
Sep 1, 2015 07:49 PM
