The BEST WAY TO REMOVE tough OEM radio screws!
Old May 11, 2005 | 01:29 AM
chinaonnitrous1's Avatar
Okay, ive read a few sad things about how people have tried to remove OEM radio screws.
I've succesfully removed over 160 of these screws without stripping a single one, on the nissans. How?
Use a dril or a screwdriver, push down on the screw as hard as you can (obviously put the radio assembley on its side on the edge of a counter so you dont smash the screw tabs)and TIGHTEN the screw as hard as you can untill you hear a
"pop"
You have now succesfully broken the screw from its FROZEN state, and now unscrew easily.
The reason you guys strip them with screwdrivers and drills...is that pushing down as hard as you can while unscrewing is working against you. Unscrew will make it push up, yet your pushing down. Really stupid. If you screw INTO it...it will break the grip and make the screw able to move. Your actually helping "break" the screw loose.
You wont strip the screws but I have shattered a few phillips #2 bits. About 5. 3 of them on this one stubborn screw out of a altima.
Old May 11, 2005 | 03:44 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
GREAT WRITE-UP!
I vote that this goes to sticky!
Old May 11, 2005 | 04:26 AM
98maximaSS's Avatar
lol when i put in my indash screen i got pissed and dremeled around the screw so the screws are still in the radio and the brackets have huge holes where the screws were haha
Old Jun 20, 2005 | 10:44 AM
Kong1965's Avatar
Mechanic's tricks
Ajax, Comet or any other powdered abrasive is perfect for giving you the grip you need on the head of a difficult screw or fastener. Keep a can in the garage, dip the head of the screwdriver or bit into the powder and get a little to stick to the end, push into the offending screw or fastener.
As a helicopter mechanic in the military, we never went anywhere without Ajax or Comet in the toolbox. Works like a champ.
BTW, it helps if you do this as soon as you realize the screw won't budge easily. If you wait until the head starts to strip, that's just less surface area to work with.
Old Jun 20, 2005 | 11:24 AM
Happy's Avatar
why was this so hard to figure out??? lol it was so easy cant believe we need a writeup for this i personally tried with a screwdrivr it didnt work so i pulled otu the drill and drilled them out simple as that LOL
Old Jun 20, 2005 | 01:38 PM
Hectic's Avatar
dude, he's giving a suggestion about how to AVOID drilling or dremeling, "why was that so hard to figure out???"
Old Jun 21, 2005 | 08:40 AM
johnson's Avatar
Wish I read this before I tried to take mine out on Saturday . I got three loose by pushing down hard and unscrewing but the last one stripped so now I have to drill it out.
Old Jun 21, 2005 | 08:54 AM
ßaller's Avatar
I used a short stubby phillips head, and a plier gripping on the handle of the phillips head, and that gives enough torque to remove it.
- ßaller
Old Jun 21, 2005 | 04:32 PM
Tony Fernandes's Avatar
Sounds good, but this was one of the first things I tried on mine...didn't work at all.
Tony
Old Jun 21, 2005 | 05:52 PM
sachmo's Avatar
i have never had a problem removing the screws
Old Jun 24, 2005 | 07:03 AM
icelandmaxima's Avatar
Maxima Fanatic
very useful information
Old Aug 24, 2006 | 08:57 PM
westler92
"pop"
You are my personal Jesus.............:tu
Searched for 30 mins!!
Old Aug 26, 2006 | 06:21 AM
1996blackmax's Avatar
I've never had an issue before, but will give this a shot on my 5th gen as I hear these screws are pretty tough to get out. Good info .
Old Sep 7, 2006 | 06:15 AM
Memphis2k1's Avatar
I have found what worked the best for me was to pick up a T-handle screwdriver from Sears. 6.99 to do 8 screws without stripping them.
Link:http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old Sep 8, 2006 | 01:59 PM
mendon99's Avatar
tastey wheat
wow.
10/10, will read again.
btw, if you just use a decent power drill and you arent weak, they'll come right off
edit: why tf was this bumped?
Old Sep 8, 2006 | 07:28 PM
djfrestyl's Avatar
Suspension Yoda
Power drill doesnt always do it. Impact drill is a different story.
Old Sep 8, 2006 | 07:31 PM
mendon99's Avatar
tastey wheat
my dewalt took em right off
Old Feb 8, 2008 | 10:23 PM
SuperStock03's Avatar
Two drill bits, some Ajax and some WD-40 down. I am trying the impact wrench tomorrow!
Old Feb 8, 2008 | 10:56 PM
Niku-Sama's Avatar
i've never had an issue removing screws and my cars are old.
or mabe its because i used a nut driver because i had hex head screws, i donno
Old Feb 9, 2008 | 07:40 AM
Snypa's Avatar
this is good.i did the same stupid **** and stripped the hell out of em.nice write-up
djfrestyl's Avatar
Suspension Yoda
You sir, are a moron.
Please read this thread in its entirety for the correct way to remove the screws.
Old Feb 19, 2008 | 07:07 AM
I30driver's Avatar
I tried using my impact drill and shattered 2 bits and broke 2 bulbs in the heater controls. I recommend NOT using an impact OR power drill, and remove the heater control unit before attempting.
Old Feb 19, 2008 | 08:34 AM
djfrestyl's Avatar
Suspension Yoda
I recommend reading this thread and following advice prior to trying anything.
Old Feb 22, 2008 | 05:41 AM
goldtooth's Avatar
LOL, QFT!
Old Feb 22, 2008 | 10:27 AM
dashan's Avatar
Very useful tip. I bought an extra large screwdriver when I did mine.
Old Feb 22, 2008 | 12:37 PM
Bborges's Avatar
OR...
you can buy an regular impact drive and a rubber hammer, loose them up and once you install the new deck with the climate control, you'll realize that the bang phucked up your climate control light bulbs!
PS. why are the screws that tight? I had to really bang the impact drive to get them out...
Old Feb 22, 2008 | 12:38 PM
Bborges's Avatar
Ha ha ha!
I shouldve read this post 4 weeks ago!
That was exactly what I used and the results are the same: broken bulbs in the climate control!
Old Feb 24, 2008 | 07:45 PM
2 Da Max's Avatar
Yea that ish was a bich, i would use the drill and press down and it worked
Old Mar 17, 2008 | 03:26 PM
daesonn's Avatar
I actually tried installing my whole stereo over the weekend and ran into a couple problems with the installation.
1. These damn screws! I had at least e different people try and get them out before I decided they were going to get stripped soon. Finally asked my dad for some help and he has a very large piece of machinery called a drill press (most of you probably don't have one) We mounted a phillips that fit the screws nicely into it, pulled the drill press down and held it as hard as we could, I grabbed onto the head unit as my dad used pliers to twist the head of the drill press, worked good on all of them except one gave us problem and then we got it out.
Drill press, or....tighten them...lol
Old Aug 9, 2010 | 04:31 PM
strongbadia5000's Avatar
They are impact screws. You have to hit the top of the screwdriver with a hammer fairly hard while turning. It would help to have a screwdriver with a wide handle and a rubber mallet. Obviously the stereo should be out and laying on its side on a table or something. You do not have to tighten them-just unscrew like normal while hitting the top of the screwdriver with a hammer. GOOD LUCK.
Old Aug 10, 2010 | 05:06 AM
djfrestyl's Avatar
Suspension Yoda
^^ How do you expect to unscrew while simultaneously hitting the top with a hammer?
Trust me. Tighten with a low torque setting on a screwgun (using the correct sized bit!) until it clicks, then loosen it right out.
Old Aug 10, 2010 | 05:29 AM
tigersharkdude's Avatar
why do noob's come on here and try to tell everyone how to work on their car? Seriously??
Old Aug 10, 2010 | 05:32 AM
djfrestyl's Avatar
Suspension Yoda
Wish I knew
Old Aug 16, 2010 | 06:33 PM
xtremepb0's Avatar
LOL
Old Aug 17, 2010 | 02:46 AM
aterfy27's Avatar
i mean...just cause he is new to the forums doesn't mean he's new to working on cars and whatnot. dude could be a professional mechanic or whatever and his low post count doesn't change that fact.
but whatever.
one hand on the screwdriver and one hand on the hammer? haha i mean i'm not saying this is the right way to do it...but you make it sound like it's quite a challenge to hold a screwdriver in one hand and a hammer in the other...
in taking my radio out, four of the radio bracket screws came out really easy. for some reason, the other side wouldn't come out for anything. this is a solid idea though. but.....my radio is working and in the dash right now so here's hoping she stays there a long time.
Old Aug 17, 2010 | 05:05 AM
djfrestyl's Avatar
Suspension Yoda
Regardless of if they're a mechanic or not, they may not be well versed in the Maxima world. Mechanics still encounter new things every day. These screws are one of the new nuances that a mechanic may encounter, and my method is the best way to remove them. I've installed a LOT of head units in Maximas. I've tried many methods, including yours - it doesn't work.
Old Aug 17, 2010 | 10:24 AM
aterfy27's Avatar
it wasn't my method, but ok
Old Aug 18, 2010 | 07:50 PM
Teaner's Avatar
2003 Nisan Maxima
regardless of the date of this thread...easiest way I have found is to just break the screw loose with a heavy 12v> cordless screwdriver/drill. don't use the automated power of the screwdriver/drill itself but just use it like its a normal screwdiver. the weight and strength of the gun will break the screws loose everytime.
Old Aug 18, 2010 | 07:57 PM
djfrestyl's Avatar
Suspension Yoda
Interesting, I'll have to try it. I always go on a low torque setting and allow the 'impact' effect to break it loose.
Old Aug 19, 2010 | 07:05 AM
Teaner's Avatar
2003 Nisan Maxima
DJ, that will work as well, but sometimes the screws get stripped no matter how careful you are. you don't need to torque the gun at all.
