4th gen RCA cable length
Old May 12, 2005 | 08:28 AM
adampecush's Avatar
because i'm a lazy bastard, im taking the easy way out here...
what length have you guys used for RCA cables when wiring an amplifier in the trunk? I'll run the cables down the passenger side, and i'm thinking that a 4M (~13ft) cable should be good enough. Anyone suggest otherwise? I want to avoid excess cable as much as possible and the next step up in length is 6M of the cables i'm buying (knukonceptz)
thanks for the help
adam
Old May 12, 2005 | 11:16 AM
Batxel's Avatar
blah
13ft will be plenty. I think I have about 2ft of slack. You could probably get away with even shorter if you take your carpets completly out and run it down the center of the car
MAXSE5SPD
Sep 17, 2022 04:00 AM
9aj9
Apr 5, 2020 12:11 AM
Violator
Sep 9, 2015 10:14 AM
pktaske
Sep 4, 2015 08:40 AM
