Installing Components in 2K2 maxima
Old May 13, 2005 | 04:25 PM
99 SE-L
Hey guys iam currently installing components in my maxiam and iam wondering how to run the speaker wire into the kick panel any help is appreciated thank you..
Old May 14, 2005 | 07:46 AM
1phtmax's Avatar
i would lick to know as well?
Old May 14, 2005 | 07:49 AM
sunten1
lick....LOL
Old May 14, 2005 | 08:21 AM
djfrestyl's Avatar
Suspension Yoda
if ure putting components in....why do u need wire in the kickpanel? dont you want to get the wire into the door?
Old May 14, 2005 | 11:27 AM
99blkgle's Avatar
im back!
well i have an 2001 i30 and not 100% sure if they are the same but from the doors i just cut a hole in the bundle, and run my wires through that and then if you look behind the bundle(black thing that connects the wires to the door) there is a small groumet, i pulled that out and cut a small hole in that and run my wires into the car. When you do that take out the kickpanel trim and look for light from the hole. there is some foam in the hole so you have to play with it for a while. you just have to take your time and learn while you do it.
Old May 16, 2005 | 06:32 PM
mdmartin92's Avatar
Not sure what you are trying to do, check out my cardomain site speaker wire pic for pics on how to run new speaker wire into the doors and through the grommet that leads to the kick panel. You can also run your tweeters into the kick panel by just dropping the wire straight down in the gap around the tweeters you will see when you remove the window "a" pillar (i think that what it's called).
FanaticMadMax
Aug 10, 2015 08:55 PM
Team STILLEN
Aug 10, 2015 04:29 PM
cmpowell86
Aug 10, 2015 12:35 AM
MikesChevelle
Aug 6, 2015 11:36 AM
