Hiding Wires
Old May 27, 2005 | 04:14 AM
BlackFlux's Avatar
Hiding Wires
What's the best way to hide wires running from the dash to the trunk? Is it possible to run the wire through this column?
Old May 27, 2005 | 04:25 AM
DcMaN's Avatar
kinda but you cant go any further back than that column thats where i hid the remote starter wire for my alarm through their. Your best bet to hide wires from the dash to the trunk is to run them along each side of the car ie driver side for power wire. If your running new wire for speakers run that wire down each side of the door like front left speaker = driver side and front rigt = passenger side. You pretty much just hide everything under the carpet.
Old May 27, 2005 | 10:05 AM
seventy5impala's Avatar
on my 2k max, i only had too lift the carpet once...and that was on the passenger floor board too go across..... but everything else. all the new speaker wire and 2 sets of RCas all fit under the plastic moldings all the way back....my carpet had like staples in it, on some plastic tabs and id assume not mess with it..... and the other side with 4 gauge wire and speaker wires..... no problems at all, just gotta make sure its not in the way of the clips....but theres plenty of room.
Old May 27, 2005 | 11:52 AM
flipxmaxima's Avatar
yah my wires are run on each side of the floors by the doors its not bad my carpet had only plastic clips and the wires are easily concealed this way
Old May 27, 2005 | 12:15 PM
BlackFlux's Avatar
So I should just run the wires under the plastic moldings? But wouldn't you still see the wires?
Old May 29, 2005 | 11:01 PM
nah tape em to the body of the car and run em under the carpet near the plastic moldings you dont see em at all trust me
Old May 30, 2005 | 03:50 PM
mendon99's Avatar
tastey wheat
no no no no. go behind your glove box, down that plastic corner there, (it pops off) then pop off the plastic door skirts you can only see with the door open, thru the pillar separating front door and back door, then under the back seat at the corner, into your trunk. done.
Old Jun 1, 2005 | 07:41 AM
Big_Ham's Avatar
MaximaFreak
Yes, you can also run up the A pillar and across the headliner down through the c-pillar to the rear. Totally possible if that's the route you want to take.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
