Antenna Problems w/ Aftermarket
Old Jun 3, 2005 | 12:06 PM
PBX's Avatar
PBX
Antenna Problems w/ Aftermarket *Solved*
So I just got the Alpine CDA-9853 installed at a local audio shop but I just realized on my way back that my antenna wont power down when I pop in a CD.
It will when I power down the whole system or turn off the car...so I called they guy and he says that all aftermarket units are like that (BS). So what needs to be done for the antenna to power down? Next time I'll just do it myself! Thanks
Old Jun 3, 2005 | 12:57 PM
keehoon's Avatar
I think their technition didn't connect power antenna wire. Check the installation manual whether yours has power antenna wire or not. If you have, tell them. Not all aftermarket units are like that.
Old Jun 3, 2005 | 01:12 PM
PBX's Avatar
PBX
The antenna powers up and down but it wont power down when switch to a CD. I would think a 350 dollar head unit would support that feature. Ill check the manual thanks...
Old Jun 3, 2005 | 01:50 PM
raga55's Avatar
All the aftermarket HUs ive had or have put in other peoples cars the power antenna is always up when the HU is powered up and this is with a pretty wide array of HUs (Pionner, Sony, Aiwa, Alpine) and cars too (2 Maximas, G20, Jeeps, Supra) so im pretty sure thats just how it is the antenna is always up, if it bothers you that much you could probably wire a switch on the power antenna wire. . .but i dont know how good of an idea that would be. . .
Old Jun 3, 2005 | 01:53 PM
flipxmaxima's Avatar
i have the same problem with my pioneer hu a fairly expensive one to.
Old Jun 3, 2005 | 02:45 PM
PBX's Avatar
PBX
Well it seems that the installer used the amp link insted of the antenna link for power. So he just switched that now everything works fine. Atleast thats how he explained it to me...
I'm guessing that some of the low end ones dont have this feature! I'll have to get some pictures for you guys later.
Old Jun 3, 2005 | 03:13 PM
PBX's Avatar
PBX
Old Jun 3, 2005 | 06:23 PM
99MAXSE-L's Avatar
unfortunately mine is like that as well. I have some JVC headunit.
Old Jun 3, 2005 | 06:47 PM
PBX's Avatar
PBX
Im surprised that so many are like that..maybe they were just wired wrong?
Check and make sure the radio has 2 remote wires. 1 for an amp and 1 for power antenna. They most likely you have it hooked to the wrong remote wire.
Old Jun 3, 2005 | 06:59 PM
LeX's Avatar
LeX
Nissan by Nature
my alpine 9833 keeps the antenna down when CD is playing. I wired the power antenna connector in to the harness and it functions as it should
Old Jun 3, 2005 | 07:28 PM
PBX's Avatar
PBX
Hey LEX...under what option in the menu can you adjust the bass. Cant seem to find it...
Old Jun 3, 2005 | 07:29 PM
Jaye_96Max's Avatar
our cars need an antenna adapter with all aftermarket radios
Old Jun 3, 2005 | 07:49 PM
Pearl96Max's Avatar
I tend to get a bit irritable
If you had that problem with Sony and Alpine then unfortunately you connected them wrong. They both have independant antenna leads.
Old Jun 4, 2005 | 04:20 AM
LeX's Avatar
LeX
Nissan by Nature
if you mean subwoofer bass just push the big volume button that brings up the subwoofer volume/options and you can adjust that.
If you want to adjust the bass frequency levels go into the user EQ by holding down the menu button for 2 seconds then cycle through the options until you get to the equalizer options
Old Jun 25, 2005 | 07:21 PM
PBX's Avatar
PBX
Thanks...i would have never figured that out. So many freaking settings!
catalinvint
Sep 16, 2015 07:48 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
