sub install with factory bose head unit
Old Jun 12, 2005 | 11:32 PM
Bella04SL's Avatar
can some one who has had it done please fill me in on price and how it is done
Old Jun 13, 2005 | 10:43 AM
kcidmil's Avatar
Well price depends upon what you're looking to install. It is very simple actually. The easiest way to do this is give us a budget range. Exactly how much are you looking to spend?
We give you a decent list of equipment that you can choose from. And the we go from there. As long as you know some basic wiring... you'll do fine.
Old Jun 13, 2005 | 11:42 AM
blkONblk01's Avatar
Just installed a phoenix gold x12d4 xenon (Very good sound quality and hits hard as hell) sub today with the factory HU you will just need everything you normally would with if you had aftermarket HU + a line output converter.
Old Jun 13, 2005 | 12:57 PM
luigi'smax's Avatar
guys...do you think two of this would be a good purchase ?? yes ..no ?? any suggestions ?? also...what amp should i use ?? should each individual sub be cnnected to an individual amp ?? thanks...
Old Jun 13, 2005 | 01:03 PM
2 Da Max's Avatar
two what? line out converters? just one is necessary. and for amps its just a matter of preference. for ie, one 1000 watt amp for 600 dollars or 2 500 watt amp for 300 dollars. its up to you, but 2 class D mono amps i think are more effiicent unless you get one nice amp. its up to you.
Old Jun 13, 2005 | 01:15 PM
mynameispee's Avatar
i have 2 12" subs and they were done by splicing the back speaker wires. no need to open up the dash.
Old Jun 14, 2005 | 10:09 PM
Bella04SL's Avatar
misunderstanding
i have 2 kenwood 12s in a bandpass box and a kenwood amp was just wondering how much the converter is and what install should cost
Old Jun 17, 2005 | 08:37 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
the converter is about 50-60 bucks around there.......it is a the PAC one.....it basically takes your bose headunit and adds a 4 CH RCA Output. I've done this and it is really easy to install. all you need to do is take out your old headunit unplug the harnesses and add in the PAC adaptor. run your RCA's to where your AMPs are and your done. you just added some RCA's to your BOSE headunit.
Old Jun 17, 2005 | 05:56 PM
wanta02max's Avatar
i picked up a converter from best buy for about 25 bucks....and i wired it in using the factory bose sub wires on the rear deck, that way no taking the bose unit out....
Old Jun 18, 2005 | 12:18 PM
gsmith795's Avatar
i was interested in doing this so i could use my 2 10" audiobahn flame q's and my JBL 1200w amp (from my old 3rd gen max with aftermarket HU and speakers) with my 4th gen stock bose system. is hooking up the PAC adapter just a plug and play process or is there some sort of more difficult wiring/splicing that needs to be done? i dont want to take apart my dash and realize i dont have the knowledge or skill on how to hook the stuff up. i already have the RCA cable and all the other wiring, its just a matter of purchasing the necesary adaptor and hooking it up.
another quick question, would it make more sense to just splice into the rear speakers, or would i be sacrificing sound quality?
melteye
May 16, 2016 12:02 AM
homeyclaus
Sep 3, 2015 06:15 PM
MikesChevelle
Aug 6, 2015 11:36 AM
