This dummy needs help
Old Jun 14, 2005 | 07:01 AM
sooner02r1's Avatar
I'm putting a Panasonic head unit in my '02 which came with bose. I got the wiring harness hooked up and all that, but there was an extra harness on the stock unit. It had 3 while the aftermarket one had 2. It appears that the third is for the amp. I can't get ANY sound to come out. Is it because I don't have that third one hooked up? How am I going to convert the RCAs coming out of the head unit to the regular speaker wire that goes into the harness??
Old Jun 14, 2005 | 09:03 AM
Prophecy1's Avatar
Wiring harness is the same from 95's to 2005.
There are 3 harness's you are correct and I take it your not using the PAC or the Scosch adapter.
The reason why your not getting sound is your not powering your amps. IE your wires arent hooked up correctly . Yes match up all wires , everything should match up.
Proph
Old Jun 14, 2005 | 08:28 PM
sooner02r1's Avatar
All the wires in the two harnesses going into the aftermarket HU are connected correctly. There is an extra harness with what appears to be amp ground and remote. I am going to connect the amp remote and ground, but there are two more wires, red and red with black tracer on that harness. What do I do with those???
Old Jun 14, 2005 | 09:04 PM
Prophecy1's Avatar
Are you sure you have the right harness? I just checked a spare harness I have lieing around and it has one red and the only wire that describes what you are stating is a negative dimmer line (orange black stripe). I would suggest you either ground it off or just cap it.
The standard orange or orange with white stripe should handle your illumination.
Proph
Old Jun 15, 2005 | 01:13 PM
sooner02r1's Avatar
Ok I'm an idiot. It works now. Sounds much better than the BOSE HU. Thanks for the help Prophecy.
Old Jun 15, 2005 | 03:22 PM
90MAXGMG's Avatar
Congrats on gettin a Panasonic! They are da shiznit. I have an older model (df600u) but it is awesome and I wouldn't buy anything other than panasonic when it comes to hu's
Old Jun 19, 2005 | 08:20 PM
S00NR1's Avatar
OU > *
Damn Adam, spending more money??? I can't wait to see (or hear) it. Although I will bet my *** that my new Bose setup still sounds better, lol.
Old Jun 24, 2005 | 09:52 AM
Zemog's Avatar
I thought the 3rd harness was for the trip computer and the steering wheel remote controls??? Correct me if I'm wrong here.
Old Jun 25, 2005 | 07:23 PM
GrazsRootz's Avatar
yeah i think they are....i wonder if there is any way to wire those up to the new sony Hu im puttin in....
Superbform
Aug 11, 2015 08:10 PM
mm347
Jan 20, 2005 09:56 PM
Matt93SE
Aug 6, 2004 02:39 PM
Julio
Apr 20, 2004 10:38 AM
cbrflyer919
Mar 3, 2002 08:39 PM
