Noobie Needs Help on Speaker Install
Old Jul 8, 2005 | 12:23 AM
MaximaZero's Avatar
Needs non-Maxima Friends
I have a 2000 GXE non-bose. I can get the door panels off with no problem, but I really don't want to have to cut any wiring. I read in another thread that there's an adapter that will allow me to plug in my aftermarket speakers, but I can't find it online anywhere. Does anyone have any advice?
Old Jul 8, 2005 | 12:33 AM
snair2's Avatar
If you don't want to cut wires, and save money on not getting harnesses, you can go the route of t-taps. Just slice into the wire enough, without cutting through it, and attach a t-tap into it, then attach (crimp) the other end of the t-tap to the speaker wire, and plug in. It will do the same thing, and you will not have to cut any wires.
Old Jul 8, 2005 | 03:05 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I believe that what you are referring to, Max0, is the Scosche adapter. That adapter is for those whom choose to upgrade the HU without unpgrading the speakers in the Blows system.
Old Jul 8, 2005 | 08:00 AM
Supa Lao's Avatar
You can get speaker harness at Circuit City
Old Jul 8, 2005 | 08:11 AM
guavo's Avatar
Could also run new speaker wire...
Or put butt connectors on the OEM wire / New wire / OEM harness, so you could easily swap the OEM harness back in if you needed to.
Crutchfield has OEM to leads converter:
http://www.crutchfield.com/S-jNUdXv9...100&I=12071027
Old Jul 8, 2005 | 09:20 AM
MaximaZero's Avatar
Thanks guys. The one guavo linked to is exactly what I'm looking for.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
videomano
Sep 8, 2015 03:28 PM
