New entire install *pics*
Old Aug 8, 2005 | 01:36 PM
  #81
2 Da Max's Avatar
nice, what amp is feeding that?
btw are you selling the 8inches? how much do you want for one?
Old Aug 8, 2005 | 07:12 PM
  #82
zad1
what amp do you have on the w6?
  #83
SEmy2K2go's Avatar
Go BUCKS!!!
My current sub amp (that I've used for years) is an MTX Thunder 2160 which so far, seems to do a really good job with this sub.
Check out my classified thread here for that info on the 3 8's.
Old Aug 8, 2005 | 07:18 PM
  #84
BBOYSTEVIE's Avatar
Back from Hibernation
looking good. I'm loving what going on w/ that head unit.
Old Aug 8, 2005 | 07:59 PM
  #85
SEmy2K2go's Avatar
Go BUCKS!!!
Yeah, the HU hasn't really had too much more work done on it just yet. I'm going to try and get something going with that in the next week or so.
Old Aug 28, 2005 | 02:56 PM
  #86
DukeN's Avatar
Wow, lookin super nice, and I bet that sub sounds crazy. Did you do anything to your car to eliminate any rattles from that thumpin sub?
Old Aug 28, 2005 | 08:01 PM
  #87
MannyNJ2k2max's Avatar
nice tim!!
Old Aug 28, 2005 | 08:09 PM
  #88
SEmy2K2go's Avatar
Go BUCKS!!!
Thanks Manny. I've decided that I'm just going to go with the GXE mounting kit. This HU install has been a major PITA. I've installed and uninstalled it about 3 times now, and haven't been happy with any of the results. Also removing the OEM faceplate is becoming quite a PITA as well.
Old Aug 28, 2005 | 11:07 PM
  #89
makdaddy386's Avatar
Originally Posted by cutter
With the iPod hardwired into your system, are you able to switch the songs with the hand controls on the steering wheel? And do you know if it is possible to hardwire the iPod into the factory HU?
The only way that this could be done is if you had an ipod adapter for your aftermarket HU. First off, you need a HU that is compatible, I know Pioneer's have an adapter for about $100 cutter for your D1, and then once you have a HU that can control your ipod, you would need a PAC adapter for the steering wheel controls. And even then you would have to have steering wheel controls that would scroll between tracks. Definetly can be done but not cheap. Also the only way to run an ipod through a factory deck would be to get an FM modulator, which will only play audio through one of your FM station's. You CANNOT control the ipod through the factory deck. Hope this helps.
Old Sep 2, 2005 | 09:08 PM
  #90
SDB318's Avatar
how did u hook up the ipod man
Old Sep 3, 2005 | 08:09 PM
  #91
SEmy2K2go's Avatar
Go BUCKS!!!
Using the equipment below, I cut one of the power outlet adaptors, grounded one wire and ran the other to a 12v source. I then plugged in the iPod Auto Kit into the outlet. On the plug portion of the iPod adaptor, there is a 1/4" jack which the Monster cable plug goes into. The other end is plugged into the AUX on the back of the Eclipse. The other end of the iPod Auto Kit cable plugs into your iPod. This charges the iPod while it plays. Also, it turns off when you turn off your car (which is something I found out last week). Hope that helps. Once my GXE mounting kit arrives, I will be taking more pics and I will get some detailed pics of the actual wiring setup that I've done.
Old Sep 3, 2005 | 08:55 PM
  #92
SXN's Avatar
SXN
why not hardwire the charger to the car instead of running that ugly power splitter? seems essentially like my set up. i run a dock that has a line out port which ive found sounds a lot nicer than running into the headphone jack. hardwired charger also running to the dock which is velcrowed in place... overall im happy
Old Sep 4, 2005 | 06:48 AM
  #93
sanmaximo2000's Avatar
where did u buy that monster cable at
Old Sep 4, 2005 | 02:53 PM
  #94
SEmy2K2go's Avatar
Go BUCKS!!!
I purchased all 3 pieces at Best Buy.
Old Sep 13, 2005 | 09:52 AM
  #95
psu711's Avatar
Wow, great thread. I am in the process of returning my pioneer ipod adapter since the interface is horrible. I think this setup will work for me until I the neo ion or Ice link have pioneer compatible models.
I followed everything you said, but am unclear on one thing.
I plan to do exactly as you said....Buy the parts you have. plug the belkin into my aux in via the rca cable. Pioneer 7700 if it matters
I dont understand how you are powering it.
1. I am pretty clueless with electronics (especially car electronics)
2. how are you powering the unit? I see the cigarette adaptor but cant imagine you would run a wire out of the c-lighter by your ash tray (seems to sloppy for a man of your "detail") =)
I couldnt really follow about what you said about, slicing and ground the wires behind the dash. Is there a "easy way" to plug a cig adapter in from behind the hu?
Sorry for being such a newb.
Old Sep 13, 2005 | 11:48 AM
  #96
SC2K1's Avatar
I believe uou can unhook the stock cigarette lighter from behind and connect the cigarette adapter shown in the pic. Then you hook the belkin car kit adapter to it. One end will plug into the new cigarette lighter and the other end will connect to the ipod or ipod dock depending how your set up is. You can hide all of the wiring behind the dash so noe of this will be showing.
You can PM kpr10is since he did my hookup.
Old Sep 13, 2005 | 11:56 AM
  #97
psu711's Avatar
Great Idea. I could prob even use the cig lighter slot to have wires come out? No?
Thanks for the help. I appreciate it!
Old Sep 13, 2005 | 06:13 PM
  #98
SDB318's Avatar
i bought that monster cable and i have to turn the volume all the way up on my hu to Barely even hear it. HELP
Old Sep 13, 2005 | 06:42 PM
  #99
SC2K1's Avatar
Do you have the monster cable plugged into the ipod directly or into a docking station? Also do you have the volume on the ipod turned all the way up?
Old Sep 13, 2005 | 07:14 PM
  #100
RandyZ's Avatar
WOW, thats a lot of work. I bet that will be a one of a kind install
Old Sep 13, 2005 | 07:16 PM
  #101
SEmy2K2go's Avatar
Go BUCKS!!!
And you have it hooked up to your AUX input on the HU?
Old Sep 13, 2005 | 07:17 PM
  #102
SEmy2K2go's Avatar
Go BUCKS!!!
Thanks. I used some other members' installs as a reference. There are some pretty nice iPod installs floating around.
Old Sep 14, 2005 | 04:31 AM
  #103
SDB318's Avatar
on the back of my hu i have rca L, R, SW. i just put it in the L, and it is plugged directly into the ipod and yes the ipod is turned all the way up
Old Sep 14, 2005 | 04:35 AM
  #104
SEmy2K2go's Avatar
Go BUCKS!!!
Those are RCA outputs. To run the iPod through your HU, you need an auxilary input set of RCA's coming from the HU. I would suggest disconnecting the iPod from your HU so you don't damage either unit.
Old Sep 14, 2005 | 12:24 PM
  #105
SDB318's Avatar
so where can i get this auxilary input
Old Sep 14, 2005 | 01:07 PM
  #106
SC2K1's Avatar
I believe your headunit either has or it doesn't. If it doesn't I think your only other option would be to get a new HU or use Itrips or something similiar.
Old Sep 15, 2005 | 04:50 AM
  #107
SDB318's Avatar
http://www.crutchfield.com/S-hDyfr3B...0&I=500KCM122B
should i use that then the monster cable
Old Sep 15, 2005 | 05:03 AM
  #108
SDB318's Avatar
or use this without the monster cable
http://www.crutchfield.com/S-hDyfr3B...0&I=500KCM123B
Old Sep 15, 2005 | 12:09 PM
  #109
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
Tim,
Any luck with the GXE dash piece?? Any final install pix??
Old Sep 15, 2005 | 12:29 PM
  #110
SEmy2K2go's Avatar
Go BUCKS!!!
Originally Posted by SgtSchulze
Tim,
Chuck...haven't picked one up yet, so I'm still running the OEM faceplate setup.
*this is the part where I blame summer for keeping me too busy*
Old Sep 15, 2005 | 12:31 PM
  #111
icelandmaxima's Avatar
Maxima Fanatic
sorry I havent gotten back to you. I'm willing to sell I just dont know whats a fair price.
Old Sep 15, 2005 | 12:34 PM
  #112
SEmy2K2go's Avatar
Go BUCKS!!!
No sweat. You have a PM.
Old Sep 18, 2005 | 12:45 AM
  #113
goobergo's Avatar
Cookin' with Gas!
what's going on here
Old Sep 18, 2005 | 12:49 AM
  #114
SEmy2K2go's Avatar
Go BUCKS!!!
How do you mean?
Old Sep 19, 2005 | 11:35 PM
  #115
SEmy2K2go's Avatar
Go BUCKS!!!
I received my GXE mounting kit today thanks to iceland. I'll be installing it either Wednesday or Thursday.
Old Sep 20, 2005 | 01:31 PM
  #116
SgtSchulze's Avatar
Did you go with a SWIX controller for the steering controls or are you just using the remote???
Old Sep 20, 2005 | 08:48 PM
  #117
SEmy2K2go's Avatar
Go BUCKS!!!
no and no...
Old Sep 22, 2005 | 08:47 AM
  #118
CoolMax's Avatar
is invisible
Incredible. We'll need a meat to see the new setup is - I thought the old one was damn good.
Old Sep 30, 2005 | 11:05 AM
  #119
SEmy2K2go's Avatar
Go BUCKS!!!
Not overly crazy about how it turned out, but I finally got around to covering the box today.
Feedback welcome.
Old Sep 30, 2005 | 11:08 AM
  #120
tripleGmax's Avatar
i like it Tim, maybe you can help me pick something out.
