NEED HELP QUICK installed new radio, and now 194 leds in the guage cluster dont work!
Subscribeok... lol i know im going to get flamed, neways i was talking to kevin last night and yesterday about this pioneer hu my boy has, he was selling it for a 140 but i gave him a buck, its brand new in the box, and its a pioneer-p660, its real nice, i love the dolphins
neways tonight from commin home from work,i turn on my lights and notice none of the guage cluster lights work, i had put these blue 194 leds in a year ago, and i know all of them couldnt blow at once. what could be the problem? which fuse should i check? all my wires behind the hu is fine, and wrapped nicely
i installed sum neons a while back nd my gauges lights were gone, then a week later in ma car my boy told why da f*k did you dim the gauges...lol check ur dimmer
btw nice radio i hav a pioneer premier...idk wut model but yea
theres soo many damm fuses, and its soo dark..
lol no the dimmer is fine, it was the first thing i checked
update, now none of the interior lights dont work, the ones in the doors for the windows, the lights on the shifter, the ac works because its digital, and i doubt its the bcm because my door lights come on when the door is open..
The fuse you are looking for is in the fusebox located under the hood. It is the 10A fuse in one of the corners, I foget which one, but that's the one you are looking for. Happened to me whn I added my 194s to my cluster too. If it shorts that means you crossed a wire possibley; that's what happened to me.
a wire? the only wires i put in are in my hu... maybe the ground is bad?? wait that makes no sense...
what else can cause thise? i just put the bulbs in and that was that..
Dude...did you totally skip by the part where I said, "If the 194 bulb leads cross it will short the circut?" Originally Posted by 2 Da Max
a wire? the only wires i put in are in my hu... maybe the ground is bad?? wait that makes no sense...what else can cause thise? i just put the bulbs in and that was that..
Most stock h/u's used to use the dimmer to dim the display. If the wire wasn't used again, it would have to be taped off. Otherwise when you were back there wiring up, you could have accidently let it touch ground.
