add on another fuse box
Old Aug 3, 2005 | 12:58 AM
gaab's Avatar
I am tring to add fuse box. it is hard to have a wire running from the driver fuse box, taking a one slot of the ignotion fuse.
help
Old Aug 3, 2005 | 06:21 AM
djfrestyl's Avatar
Suspension Yoda
Please provide more information.
Old Aug 3, 2005 | 03:14 PM
gaab's Avatar
adding fuse box:
Run wire from fuse box on the driver side
On the other end connect the Additional fuse box (new one)
When you turn the Iginotion off, the Fuse Box kill the power to i
this will help be adding more devices such as
Rarad dector
Pioneer Ipod device
Unider BCT 8
Lasser Jammer called Blinder M-20
these all will turn on when the key is on in the ignotion, and off when I take the key off.
I tried to take the fuse box the one on the drive side, but could not.
So I added a wire to it( one with slod empty) to The new Fuse box.
Q: if I am running 10 amp of each divce do What size of amp I need in the fuse box(driver side), is it:
The total of all devices, ex. 10+10+10= 30amp
The same size only 10 amp
help needed from all member.
Old Aug 3, 2005 | 09:27 PM
djfrestyl's Avatar
Suspension Yoda
total of all devices, plus a little extra. Then each individual device in the secondary fuse box should have a fuse in the amperage that the device requires.
but....I don't suggest piggybacking off the fuse box in the first place. Run a dedicated wire to the battery.
Old Aug 4, 2005 | 12:32 AM
gaab's Avatar
if I run it stright from the battery, the battery will die even the car it self turned off.
MaxiNoob98
Oct 2, 2015 10:13 PM
leatherneck
Sep 30, 2015 09:16 PM
Redfox
Sep 28, 2015 10:41 AM
Sep 27, 2015 08:37 AM
