FM reception - aftermarket HU - 5th gen
Old Aug 10, 2005 | 09:28 AM
3DazeGrace's Avatar
yo homies
got my aftermarket stereo stuff installed (replaced bose) and now it seems like i get mostly bad reception, i have a 2002 and for some reason there is no antenna on these things, maybe its hidden in the back window or somthing i dunno
did they do somthing wrong or do other people have this problem
also when they integrated my steering wheel controls when i hit the track up button it always skips 2 ahead, but the down button works fine, so thats why im thinking maybe its the installers but i wanted to make sure it wasnt a known maxima issue
Old Aug 10, 2005 | 10:00 AM
Adrian's Avatar
I dont get good FM reception - aftermarket HU either
Old Aug 10, 2005 | 07:47 PM
3DazeGrace's Avatar
what kind do you have, i have a kenwood with the flipdown thingy
anyone else have this problem, i think im going to call and complain
Old Aug 11, 2005 | 06:42 AM
Adrian's Avatar
kenwood ktv911
Old Aug 11, 2005 | 04:02 PM
shoman94's Avatar
On the antenna adapter....with 2 pins....install it opposite the way it is supposed to go in. In other wods the locks on the plugs wont latch.....worked for me......
-Jason
Old Aug 11, 2005 | 08:55 PM
TheBigDu's Avatar
Supposedly this is a problem with all aftermarket HUs. Our cars have the antenna in the rear window. The 2-pin system is apparently designed to work with the stock HU because it has special tuning built-in that properly combines the two signals to produce "good" reception. Aftermarket HUs are designed for regular antennas and do not have the special tuning required to decode the signals or whatever from the stock antenna in these cars.
I believe the only thing you can do is install a separate aftermarket antenna.
Old Aug 11, 2005 | 11:40 PM
MiniRX7's Avatar
According to an installer i met, he explains that the reason is a difference in impedence between a regular antenna and a dual diversity antenna in the maxima.
Nothing can be done.
Old Aug 12, 2005 | 12:05 AM
OutMaxxed's Avatar
i had the same exact problem... i went with satelite radio... Solved my probelm...
Old Aug 12, 2005 | 12:45 AM
mclarengts1's Avatar
yeah i have that problem too
Old Aug 12, 2005 | 05:59 AM
3DazeGrace's Avatar
-Jason
did anyone try this guy's workaround?
the antenna adapter is behind the HU right in the dash?
ill have to tell the installers to give it a wing
Old Aug 12, 2005 | 07:08 AM
TheBigDu's Avatar
I tried this, and I don't remember it solving anything, but to be fair, I didn't give it much time. I really don't see how this would work anyway.
Old Aug 12, 2005 | 07:16 AM
Ephraim's Avatar
i had the exact same problem, and i saw a thread on here and i fixed it. im not sure if i am describing it right, if you have the bosch wiring unit and you connect all the wires together i think there is a subwoofer wire that is not connected to anything, and it tells you not to connect it. well if you connect it to the ground wires then the radio works fine.
again im not sure if it is a subwoofer wire or what it is, but that was the problem for me and a handful of other guys on here.
Old Aug 12, 2005 | 07:22 AM
TheBigDu's Avatar
Since when does Bosch make wiring harnesses for aftermarket HUs?
Old Aug 12, 2005 | 08:41 AM
3DazeGrace's Avatar
i guess ill try more google searches against the maxima org for the fix
it should be a sticky
Old Aug 12, 2005 | 12:19 PM
Ephraim's Avatar
i had a scosche harness
Old Dec 7, 2005 | 08:41 AM
ypl102's Avatar
it works to certain extent
it worked by doubling my signal strength(more volume) however, the static noice is still audible. After reading this I confirmed my diversity pins are fine since no problem with factory. And finally the reason it make the difference by reversing which I did also was apparantly only one of the recepticle holes has a connection leading to the single plug(look inside you'll see the metal). and apparantly by switching, the louder signal from the opposite diversity lead was able to go through . . ..
Old Dec 7, 2005 | 08:44 AM
ypl102's Avatar
could it be the dimmer negative wire?
the only wire i have unconnected is the dimmer negative wire but it is shielded .. . let me groud this baby out to see. . .
Old Dec 15, 2005 | 07:05 AM
ypl102's Avatar
no more noise
after market antenna didn't solve the problem. Make sure to ground the HU to itself, providing same ground as power antenna since there's no ground in factory wiring and grounding to the back chassis didn't provide common ground with the antenna. it's not a diversity antenna issue since it has the window antenna in addition to the regular antenna and if you use the after market antenna adaptor, you are effectively using the regular antenna unless you reverse the adaptor as one OP suggested.
Old Dec 15, 2005 | 09:24 AM
ElVito1981's Avatar
i have a 3rd gen. maxima and an eclipse head unit. I was thinking about listening to just FM radio. So you guys think that I'm gonna get crappy reception with the Eclipse head unit? If so, what should I do? Should I try to buy a 3rd gen. stock radio receiver? Or should I try to change my stock antenna and keep the Eclipse?
Old Dec 16, 2005 | 04:55 PM
Biggs_02's Avatar
did you guys remember to hook up the power antenna wire? without it i get like 2 stations. After i hooked it up my reception is phenomenal
Old Dec 17, 2005 | 08:28 AM
ypl102's Avatar
i get all the stations the factory HU used to get, it's just some distant ones sound staticky, which is quite normal
Old Dec 17, 2005 | 11:31 AM
djfrestyl's Avatar
Suspension Yoda
On your metra/scosche wiring harness, make sure the solid blue wire is hooked up to the blue/white wire coming out of the aftermarket head unit. Thats the power antenna wire, and by connecting it to remote turn on you are essentially "amplifying" the signal, in not so many words.
Old Dec 24, 2005 | 08:48 AM
ypl102's Avatar
just to clarify: On the 03, My antenna 12V power lead coming out of the SONY HU is solid blue which gets connected to metra's blue which is connected to the factory green/white. My SONY's blue/white wire is the AMP remote turn on, not to be confused with the power antenna.
Old Dec 24, 2005 | 11:53 AM
djfrestyl's Avatar
Suspension Yoda
That is correct, but throw out the Sony HU
Old Dec 25, 2005 | 07:02 AM
ypl102's Avatar
i like the 120dB S/N for cds, crisp sound. Ya think it's the cause of my FM problem? I've heard of bad receptions with other HUs though . . .
Old Dec 25, 2005 | 12:44 PM
unrealii's Avatar
I've never had any problems with fm reception.
Here is how my setup is like, maybe that will help some of you:
-Eclipse cd8454 / 8455 - both get good reception
-Grounded to chasis - there are two nuts at the bottom of the dash when you pull the radio/climate assy out, I unbolted one nut and grounded my hu over there along with my pac swi-x Picture of my grounding point
-I'm using some antenna adapter which converts the nissan 2 pin plug into a single plug for my hu to accept. I dont know what brand it is. There were two of them there because the dealer installed a pos fm modulated 12 disc cd changer instead of the bose 6disc when the car was purchased new. I only ended up using one of them. Picture of my antenna adapter
-Power antenna wire from hu is connected to power antenna wire from metra harness.
Old Dec 25, 2005 | 07:24 PM
ElVito1981's Avatar
yeah, but the highest Eclipse HU has a S/N ratio of 100 db, so even if CDs are 120 db, unless the decoder has a S/N ratio of 120 db, you won't be enjoying the CDs to the fullest.
Old Dec 25, 2005 | 08:43 PM
maxwannabenow's Avatar
I bought my 2000 Max back in March and it had an aftermarket HU with very bad reception on all stations. I took it to the stereo store to get it fixed. They said that the diversity antenna in the back glass had a antenna amplifier or booster that did not have the turn on lead connected to the aftermarket HU. They connected it and now I have great reception.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
