Alpine Type R components in a 96 i30
They need to be slightly larger than the outside diameter of the basket and approximately 1/2" thick so the basket will lay on and mount to the surface after the ring is mounted to the door.
http://www.forums.maxima.org/showthr...=424423&page=4
The last pic in post 113 will give you a good idea. Although it is a 5th gen, the concept it exactly the same.
now with the baffle, there is still enough clearence for the speaker excursion? cause a half inch in there is a decent amount of room taken up.
also have any of you put rear speakers in your doors in your max's or I's 96-99, i have a jl e2150 that i could use to power my components and then i can use a 4 channel amp to power the rear set of speakers.
the new ones are 2 3/4 mounting depth, thats not bad
http://www.crutchfield.com/S-dZOu6Mz...500SPR17LS#Tab
Yes.
Yes. I have a second set of components in the rear doors. I would recommend just a pair of coaxials.
hard to do man? i have like limited **** to work with here, plus id need a beige colored speaker cover to have it blend in, i want it to look stock, well yours is also anewer model than mine
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
RealityCheck
Oct 2, 2015 06:34 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
