Replacement Free Air Sub?
Old Sep 25, 2005 | 10:50 AM
mclee45's Avatar
I've been trying to find an aftermarket Free air sub to replace my 8" bose on my 2000 Maxima. I can't seem to find any Free air 8" subs anywhere. Went to circuit city, best buy and mobile one and none of them sells free air. Anyone know where I can get a 8" free air sub that fits perfectly as a replacement?
Old Sep 25, 2005 | 10:52 AM
nismos14's Avatar
§è~® f®ÈÄk
You'd probably have to look on-line first of all.
Old Sep 25, 2005 | 12:26 PM
kpr10is's Avatar
Image Dynamics makes a couple decent ones. Check em out.
Keep in mind youll have to deaden the rear deck, and probably make a plate out of mdf to screw the sub into. Screw holes hardly ever match up. Just fyi. What amp are you planning on running?
Old Sep 25, 2005 | 02:44 PM
mclee45's Avatar
I'm running a Alpine 5 ch amp right now.
Sub output is 350W max but I'm not planning on running it that high. just want something better then the crappy bose i have.
Old Sep 25, 2005 | 02:55 PM
SC2K1's Avatar
I have the Image Dynamics ID8 and I'm pretty pleased with it. The sound is pretty clean and the bass is tight and punchy.
http://www.cardomain.com/item/IDSID8V3D4
Old Sep 25, 2005 | 09:04 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
can also check out usd audio and elemental designs
Old Sep 29, 2005 | 11:59 AM
BBOYSTEVIE's Avatar
Back from Hibernation
I would also recommend the ID8 for this application. I think diamond and a few other companies make a freeair sub or two. ID is the one I have experience with, and it does very well for an 8, does great freeair, and is under 100 bucks.
Yes you should dampen deck, block any air holes, mount to MDF....to get optimal performance.
Old Sep 29, 2005 | 12:46 PM
myktek's Avatar
there are several others that make them, but they are harder to find, online is your best bet.
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
95Maxi
35
Sep 2, 2015 10:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
