quick fuse question...
Old Sep 26, 2005 | 05:22 PM
AscendantMax's Avatar
Well...I currently have a 60 amp fuse under the hood on the main power cable. I will be running a distro block with ANL fuse holders. My fosgate amp requires a 60 amp fuse, and the amp I will be getting needs a 90 amp fuse. Question is...do I just get a bigger fuse under the hood and run smaller ANL fuses on the distro block? Is there a forumula or something that helps you figure out what amperage fuse go where along the power path?
any insights appreciated
Old Sep 26, 2005 | 05:24 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
The amp will only draw as much power as it needs...consider it a floodgate.
The gates only open to allow the water it NEEDS, even if there is more than enough behind it.
Out of the distro, simply fuse each power wire with the proper fuse and you'll be right as rain.
Old Sep 27, 2005 | 05:37 PM
so i should just keep the same fuse under the hood?
Old Sep 27, 2005 | 05:40 PM
DcMaN's Avatar
you can upgrade it wont hurt. Personally i would just incase. But basically if anything happens its gonne pop the fuse in the distro. Instead of the one at the battery.
Old Sep 27, 2005 | 05:43 PM
Garrick's Avatar
While we're on the fuse subject. Does anybody know the fuse for the light in the ignition ring?
Old Sep 27, 2005 | 07:56 PM
slickrick's Avatar
go with 80 amp gordon under the hood...80 amps being pulled from 4 gauge is not a problem. depending on which sub amp you have it should be a high enough fuse rating.
Old Sep 28, 2005 | 10:33 PM
hmm...sounds good...
Old Sep 29, 2005 | 02:10 PM
KCMaxima98's Avatar
You may not need a bigger fuse at all. The worst thing that will happen is you will blow it. Both my fosgate amps suggest 60 amp fuses each but they share a 60 at the battery and have never blown it. One is running 2 ohm stereo and one is running at 4ohm mono. At the distro block I had a 30 amp fuse on each amplifier until the sub amp blew its. I now have a 60 going to it at the distro block and the 30 going to the other one still. But combined they still don't blow the 60 amp fuse at the battery. RF class A/B amps must be really efficient.
Old Sep 29, 2005 | 09:05 PM
Garrick's Avatar
??? Why do people in this forum ignore me?
Old Sep 29, 2005 | 09:06 PM
slickrick's Avatar
because you are way OT in a thread thats NOT yours. dont expect people to come into this thread looking to help you when you didnt start it.
Old Sep 29, 2005 | 09:36 PM
Garrick's Avatar
huh? The forum of the thread? Because this is the third time I ask a question in this forum and get ignored.
Old Sep 29, 2005 | 09:39 PM
kpr10is's Avatar
You are still asking questions in a thread that is not yours.
Old Sep 29, 2005 | 09:41 PM
kcidmil's Avatar
Because we deal with car stereo, and electronics along those lines (radar detectors, nav units, mobile video, etc...) Try going up to the 4th gen forum. Though I must warn you about some of the ricer wannabes in that area.
and the biggest thing kpr10is is getting upset about is the fact you can MAKE your own thread, instead of jacking someone elses.
Old Sep 29, 2005 | 09:48 PM
kpr10is's Avatar
Im not upset at all, I was simply mocking his ignorance and not knowing what a thread versus a "forum" is
Old Sep 29, 2005 | 09:50 PM
Garrick's Avatar
Aren't fuses, L.E.D'S considered electronics? If you want "radar detectors, nav units, mobile video, etc..." as a forum you should put that. And I though I would ask a quick question about a fuse if that is the topic of the thread.
Old Sep 29, 2005 | 09:55 PM
filtor1's Avatar
Start your own thread man. You will get more responses. More people will see your question. Maybe the people in this thread don't know the answer to your question.
Old Sep 29, 2005 | 09:58 PM
*puts water on fire*
i don't think it's a fuse problem if only the ignition ring light is out. several things are usually linked up to a fuse, not just a single tiny bulb.
Old Sep 29, 2005 | 10:00 PM
Garrick's Avatar
Thank you. S**t. That's all I wanted to know. I didn't know I would get flamed by a bunch of uptight f*gs.
Old Sep 29, 2005 | 10:03 PM
well they DO have a point
so i wouldn't call them 'uptight'...
Old Sep 29, 2005 | 11:52 PM
kpr10is's Avatar
Hey newb, not to be a d!ck, but this is your friendly warning to the org. Say this to any of the 4th or 5th gen guys, or ***** up other peoples threads with your newb questions in there, and Ill put money on you getting a vacation. We have a point. Not only that, how hard is it to test your own fuses, honestly?
Old Sep 30, 2005 | 12:01 AM
filtor1's Avatar
Ouch. And he wonder why noone pays him any attention. New topic=new thread. Period. Good luck getting an help from us in the future. I wouldn't have answered it anyway in the middle of someone elses thread. Now the thread is full of crap.
Old Sep 30, 2005 | 12:03 AM
slickrick's Avatar
lol yay the org has a new Avi!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!
Old Sep 30, 2005 | 12:04 AM
kpr10is's Avatar
damn thats the insult of all insults
Old Sep 30, 2005 | 12:05 AM
slickrick's Avatar
if he only knew 1/10 of it.
Old Sep 30, 2005 | 07:51 AM
Don can always trim up threads to get it back on topic...
Old Sep 30, 2005 | 08:41 AM
kcidmil's Avatar
Yep... the only way I could understand trying to break in like that is if he was a newb with less than 15 posts
Old Sep 30, 2005 | 08:59 AM
filtor1's Avatar
No worries. Just more posts for me...
Old Sep 30, 2005 | 02:16 PM
Garrick's Avatar
If I had a quick question I don't see what the d**n problem is. As to my comment on me getting ignored, I see it doesn't take much to get a couple of losers that live in their mother's basement ticked off. I made a little question about me getting ignored to get my question across and I get flamed by a bunch of Dungeons and Dragons players trying to talk big on the forum.
Old Sep 30, 2005 | 02:34 PM
nismos14's Avatar
§è~® f®ÈÄk
IBTB
Old Sep 30, 2005 | 02:39 PM
slickrick's Avatar
the flaming came from you 1st my friend.
Old Sep 30, 2005 | 04:17 PM
kcidmil's Avatar
wow... you live in your mother's basement, and play D&D... how 80s... :
Not only are you flirting with a vacation... your acting like that D&D playing, mother's basement *****... trying to gain what's left of your pride because you know we all were right.
Not only that, you're so self centered you didn't even take the advice that was given to try the 4th gen forum.
And like I stated before, we're annoyed because you thread jacked, with a question that doesn't even remotely come close to the topic on hand. All you had to do was start a new thread. We expect this behavior of yours from newbs with less than 15 posts, not people who've been on here for awhile.
Old Sep 30, 2005 | 05:28 PM
kpr10is's Avatar
Im done with this thread. Garrick come back when you grow up.
Old Oct 1, 2005 | 05:23 AM
filtor1's Avatar
I have never played D&D. But how did you know I lived in my mothers basement?
Seriously, get over it and move on. In a month we will have all forgetten about this. Play by the rules is all we are saying. And when you don't, then wonder why we ignore you, then get your man panties in a wad, don't be shocked. Unless your into that kind of thing?
Old Oct 1, 2005 | 05:26 AM
filtor1's Avatar
I tried to help him out. I tried to give him a kind nudge in the right direction. I really think he doesn't like me.
Old Oct 1, 2005 | 07:35 PM
ObsidianIce69's Avatar
Well to get this back on topic. It seems that the consensus is to use a 80-90 Amp on the cable running to the distribution block, but what about the cables running from the block to the amps, that seemed to be the second part of his question....does he use what the amp recommends? or can he go smaller since technically there's a larger fuse up the line? I'm curious as well because i'm going from a single amp to multiple amps as well
Old Oct 1, 2005 | 08:39 PM
heh thought this thread was irredeemable...
but yeah, what size fuses would i need in the distro block?
Old Oct 1, 2005 | 08:42 PM
kcidmil's Avatar
I could ruin the thread for you...
Old Oct 2, 2005 | 12:02 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
leatherneck
Sep 30, 2015 09:16 PM
conansriver
Sep 16, 2015 12:17 PM
