Just so you grasp the shear size
Old Oct 6, 2005 | 07:08 PM
kcidmil's Avatar
Well I finally have a chance to get a pic of my box and subs outside the truck. This thing is a little over 80 lbs, and my seats had to be taken out so this giant could be removed.
Here's a shot up next to my Maxima (stock height). Now I have to find someone to take this giant off my hands. The subs will be moved over to the Maxima.
Old Oct 6, 2005 | 07:15 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Sweet Jesus. How much did you hit with that?
Old Oct 6, 2005 | 07:20 PM
slickrick's Avatar
i believe upper 140's he said...
Old Oct 6, 2005 | 08:04 PM
kcidmil's Avatar
147.1 is the best I could get it to do with the MCD500 amp. I was looking to break 150s with the MCD1100. But won't be doing that anytime soon.
Old Oct 7, 2005 | 08:00 AM
AscendantMax's Avatar
what are the subs wired down to?
Old Oct 7, 2005 | 09:09 AM
kcidmil's Avatar
the current setup of the wiring puts the subs to 1 ohm.
Old Oct 7, 2005 | 03:59 PM
kcidmil's Avatar
The subs look dull black in that photo above, which they're actually not. Here's a better pic
Old Oct 7, 2005 | 04:28 PM
MainSource's Avatar
Hit 'em with the stun gun
Nice isht. All four subs are going into the max? How's that gonna work?
Old Oct 7, 2005 | 06:14 PM
jigga123's Avatar
was that on a TL? If so thats one helluva score. Nice looking box though, get a amp that does it more justice
Old Oct 7, 2005 | 07:26 PM
kcidmil's Avatar
So far I'm not quite sure on what design I want for placement of the subs. It will be a whole new box though. I just have to find someone to buy my old one.
As for the score, that was on a 2 week old TL mic at the time. The MCD1100 amp is the perfect amp for the setup. It's the only amp that is actually rated to do 1 ohm from Memphis besides the MCD4kW. But 4000 watts would blow those subs.
Old Oct 7, 2005 | 11:39 PM
that shiny cone must add like .7 dB's...
jk
worked out a box plan for the max yet?
Old Oct 8, 2005 | 07:13 AM
kcidmil's Avatar
I've thought of a couple.
1.) Having a false floor installed, with 2 subs in the corners, 2 subs toward the seats, and the amp under plexy in the middle.
----OO
---amp
O-------O
2.) same setup for the subs listed above, amp on a false wall in the back, vent installed towards the middle.
---amp
---OO
O VENT O
3.) subs lined up in a WIDE U-shape from fender wells towards the tail. Amp on a angle rack facing right up top when the trunk is opened.
4.) subs in a broken V-shape, with the amp at the apex.
-\_/
That's about all I can think of right now (EDIT) stupid spacing correction, I made everything as close as I could using the dash lines, which represent nothing
Old Oct 8, 2005 | 09:19 AM
what about a IB setup?
Old Oct 8, 2005 | 09:31 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
i would say number two. I just worked out mine for a single sub, and the amount of space you loose multiple ported is bananas. I had three 10s and had to pull em, but the single e-quake is gonna be close to the same box size just not as deep.
i have an orion 275R if your interested, as it may be lower than the memphis as well as a 1200d. Either way nice setup and cant wait to see pics.
Old Oct 8, 2005 | 09:47 AM
kcidmil's Avatar
I could always do #4 and put a vent right above or below the amp. The only thing is, the subs will call for a total of 6 cu.ft. of air space inside the box. The old box was 8 cu.ft.
Old Oct 8, 2005 | 01:06 PM
2 Da Max's Avatar
daam thats a huge fawkin box
Old Oct 8, 2005 | 01:31 PM
kcidmil's Avatar
A little late there 2 Da Max. Now we're talking about what style of box would be best to use in the Maxima for those subs.
it did look smaller in my truck didn't it?
Old Oct 8, 2005 | 04:50 PM
how wide is that box? maybe you can cram it into the trunk somehow. my last box was 35" wide.
Old Oct 8, 2005 | 04:53 PM
kcidmil's Avatar
if I used that box, I would be limited to 2 different installs.
1. facing back,
2. facing front
In the pic, the box is 49 1/4" tall, the trunk is 50 1/4" wide at the opening.
Old Oct 8, 2005 | 04:55 PM
kcidmil's Avatar
and that's even assuming I would still be able to close my trunk.
Old Oct 8, 2005 | 04:56 PM
haha, that's TWO whole options right there!
in any case, when are you getting that bigger amp?
Old Oct 8, 2005 | 04:57 PM
kcidmil's Avatar
tax return. I might do the box up myself this time.... yeah right
Miket2006
Mar 1, 2021 03:55 AM
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
knight_yyz
Nov 1, 2015 01:34 PM
