Sub Box Problem
Old Nov 8, 2005 | 08:56 AM
WxAxGxS's Avatar
Sub Box Problem
Ok, one more question. My buddy built my sub box for me (according to the design recommended by DIamond Audio). The Sub diameter is 9.2", but he cut it to ~9.5", leaving quite a bit of slop. How bad is this and what can I do to save the box. He already glued and screwed, so taking the baffle off will not be fun.
Thanks!
Old Nov 13, 2005 | 10:06 PM
sodie14's Avatar
not a big deal as long as there are no gaps where air can leak out...just screw the sub in tight and let er rip
Old Nov 13, 2005 | 10:33 PM
AscendantMax's Avatar
he might run into the problem of not enough material for the screws to bite into when he has the sub's mounting ring centered in the cutout.
Old Nov 13, 2005 | 11:14 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
you can attempt to build the ring back up with fibergrlass. wouldnt be too hard, but the way that i would do it is to router out a ring that mounts to the front of the box, then the woofer mounts to the ring. if you want you could then glass the front of the box from behind the ring for strength. Does that make sense? alright figure you could do a ring on the front face of the box. screw it to the box. then screw the speaker on. or you can go with screwing a piece of thinner mdf on and cutting the new hole then building the back up with glass... I would go for the first. .
Old Nov 14, 2005 | 05:29 AM
WxAxGxS's Avatar
Alright, thanks. I've got plenty of MDF left, so if I can't get the screws to bite, I'll first try getting the original baffle off and replacing it. If that doesn't work, I'll try your advice!
Are there any sound quality issues with not having a tight fit?
Old Nov 14, 2005 | 05:57 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Make a ring large enough for the sub with a large lip. Then screw the lip of the ring to the box, seal with wood glue.
Old Nov 14, 2005 | 06:53 AM
Chocolate_Boi_1Der
yeah guess that was an easier way to say it ***Damn you metal and your incongruent use of comprehensible sentence structure***
lol as for the sound it would really depreciate if it isnt sealed.
Old Nov 14, 2005 | 07:02 AM
Yeah, my bad. Eloquence is often at a big 0 in the wee hours of the morning.
If he used an appreciable amount of wood glue he would not have a problem with the seal. Moreover, he could also run a bead of caulk around the ring, or the "flange" in order to ensure a complete seal.
Old Nov 14, 2005 | 07:25 AM
KyMan's Avatar
Make sure to caulk the inside joints of your box before you drop your sub in. Air leaks steal sound levels and quality. (yeah, I used like 1/2 a tube of silicone on the inside of my box).
Old Nov 14, 2005 | 07:39 AM
1/2 a tube of K-Y?
Old Nov 14, 2005 | 08:30 AM
KyMan's Avatar
you know it! it seals like a ***** ****er!
Old Nov 14, 2005 | 10:15 AM
Sense of humor for teh win.
Old Nov 25, 2005 | 01:22 AM
sodie14's Avatar
is it a sealed box or a vented box?
Old Nov 25, 2005 | 07:38 AM
Chocolate_Boi_1Der
wouldnt really matter. if its a ported enclosure any leaks would change the tuning frequency of the box, and again depreciate sound
matts95max
Apr 23, 2025 10:44 AM
bumpypickle
Sep 20, 2015 08:22 AM
Stagnet04
Sep 14, 2015 11:28 PM
Colossus
Sep 9, 2015 05:46 AM
