Passenger Side Door Problem
Ok, I have a problem. None of the speakers on my passenger side door works, the tweeters and the speaker dont work.. So we tried, and put another speaker... Still did not work. So i'm thinking the speaker wire blew.. Is that what happen? And if so, how much would it be to get the speaker wires replaced. And where can I go to get it done, I miss my speakers in the front
Do you have Bose? If so, did you swap the whole speaker/amp in the door, or just the speaker? If you replaced the whole speaker/amp, then did you test the output of the head unit?
Any shop will be able to run all new speaker wires for you but it wont be cheap. Theres probably another cause, speaker wires usually dont just 'blow'.
Good luck
Kevin
Good luck
Kevin
03VQMAX
Dec 7, 2015 04:59 PM
lux97Max
Sep 14, 2015 03:54 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
RealityCheck
Aug 5, 2015 06:18 AM
