what kinda RCA?? what kind of FUSEE???
i have 2 questions as the title states.....
1. Im planning on running 1500 watts, and i heard that RCA cables matter.... what kinda RCA cables do i need for good sound? can i get just some average monster cable RCA?
2. and w/ that kinda watt, what kinda fuse do i need? i heard 100 amp is fine? is that enough? a wafer fuse? or do i need 160 amp...
i didnt receive the amp yet, so i will look in the manual when it arrives. just trying to get a jump on the stuff i need.... and what happens if i run them on the same side? if the audio cables are shielded would it stil lbe affected/
at 11 volts it will draw 136 amps
at 12 volts it will draw 125 amps
You will need a 150 amp blade type fuse.
I seriously hope you replaced your alternator(110 amp stock) with a bigger model and beefed up your grounding system, or this is going to get messy.
you can run the rcas for a sub the same side as the power wire...the frequency at which power wire causes interference is a higher frequency than what your sub will even play...obviously then you do NOT want to run your rcas for speakers next to power wire...almost any rcas, no matter how well shielded, will still be interfered by a larger power wire (0 or 4 gauge)...
magiconthetire
Oct 26, 2015 09:03 PM
