XM Sirus switch?
Old Feb 2, 2006 | 11:18 AM
Mr.Sparkle's Avatar
XM Sirus switch?
I have both the xm and sirus modules. I want to listen to howard in the morning but sirus sound quality sux so I switch to xm for music but its a pain switching the modules all the time. Is there an aftermaket switch for both?
Old Feb 2, 2006 | 12:26 PM
mkoscal's Avatar
How do you connect up the modules to the radio?
I may not be very fussy but I have not had any sound qaulity issues since switching from the fm output of the satellite radio to using the antenna output to an external switcher. If you used PAC, it has two aux inputs so you could connect each of your satellite radios.
Old Feb 2, 2006 | 06:42 PM
tb2211's Avatar
what method did you use to install your Sirius? I just had one installed and it sound like cr*p as well. Any idea's on how to improve the sound quality?
Old Feb 3, 2006 | 06:03 AM
Mr.Sparkle's Avatar
I bought the module that goes into the trunk and connects to the standard satelite harness. Its very easy to swap them, u simply unplug one and plug the other one in but it gets really old when u have to do it everyday. It sounds like crap because sirus has crappy compression method. I have a very high end audio system in my car and it really brings out the compression artifacts in sirus.
Old Feb 3, 2006 | 06:14 AM
willis's Avatar
My heroine
buy an aftermarket head unit that supports both services and do it that way..
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
