help please!
Old Feb 11, 2006 | 03:21 PM
trinking's Avatar
help please!
alright...ive been tryin to get my system to work for about 2 weeks now..cant figure the problem out..cars a 98 maxima.. head unit is sony xplod cdx-ca810x.. now the back of the head unit looks like this 1 theres the 3 spots(audio in, rear out, front out) for rca cables then the black one hangin out..i got my rca plugged into the black one and ran to an alpine mrv-f352 amp (which is this 2 )... which is pushin 2 12" m3 motosport subs... i know this sounds ****ty but im broke.. so the amp and subs were in my friends jetta with no problem..so im thinking it must be the head unit... i tried a different amp and it was still the same...amps gettin power everything hookt up correctly, even bougt new rca's still no sound.. i have the rca ran to channel 5, sub wires ran to channel 5, and the back of amp is set to channel 5...please somebody tell em what to do..
Old Feb 11, 2006 | 03:38 PM
djfrestyl's Avatar
Suspension Yoda
Are you sure you connected your RCA's to the right output?
Post a picture of what it looks like and what you're connecting to. Did you try the other outputs?
Old Feb 11, 2006 | 04:21 PM
trinking's Avatar
i connected the rca's from the black rcas on the head unit..then i ran them to each output on the amp and still nothing...could it be the ground? i read somewhere the ground might be good enough to show power on the amp but not good enough to push the subs
Old Feb 11, 2006 | 04:24 PM
djfrestyl's Avatar
Suspension Yoda
Is that black output LABELED sub output?
What about your amp...sometimes there's numerous inputs and you have to select the right input.
Are your gains set correctly?
Old Feb 11, 2006 | 05:02 PM
DcMaN's Avatar
chances are that the black out put is not a output. Try using the rear or front rca outs.
Old Feb 11, 2006 | 05:33 PM
trinking's Avatar
pic of back of head unit:
http://www.audiosavings.com/popup.ph...A810X_BACK.jpg
pic of amp:
http://cgi.ebay.com/Alpine-MRV-F352-...QQcmdZViewItem
theres three ports from the HU for hte rca's and the black one. the three there say rear out, front out, and audio in. then the black one which isnt labeled. the amp has 5 channels. i got the amp all set to 5 and sub wires ran to 5..where should my gains be set exacly? ...am i missin something?
im gonna try more **** tomorrow cuz its snowin like a ***** here
Old Feb 11, 2006 | 05:53 PM
djfrestyl's Avatar
Suspension Yoda
Have you even TRIED with the other outputs?
Why don't you read the manual of the HU to see if that's actually an output rather than just assume that it's the exact one that you need.
Old Feb 11, 2006 | 07:50 PM
trinking's Avatar
i TRIED all the outputs...i dont have the manual..but the other outputs are the output for the front speakers and for rear speakers..the other one says audio in...none of them have to do with the subs that i know of...
Old Feb 11, 2006 | 08:19 PM
AscendantMax's Avatar
the gains on the amps aren't turned all the way down right?
Old Feb 11, 2006 | 08:39 PM
Pearl96Max's Avatar
I tend to get a bit irritable
try plugging into the front inputs on the amp...
Old Feb 11, 2006 | 11:21 PM
nismos14's Avatar
§è~® f®ÈÄk
Maybe somethings blown. Or if you bought used you got bad stuff.
Old Feb 12, 2006 | 08:46 AM
9Nails's Avatar
To rule out your amp being the problem, get a headphone to RCA jack adapter and use a walkman to test your amp as it is mounted and powered on in the car. Put your walkman on medium volume level and you should be able to play music through your car's amp and everything should be good. If you hear music, your amp(s) are definitly good and you need to take a long hard look at the head unit.
Old Feb 12, 2006 | 11:47 AM
take a DMM and see if there's anything coming out of the preouts on the HU.
Old Feb 12, 2006 | 02:41 PM
trinking's Avatar
aight guys thanks for all your input..ive pretty much tried everything i could think of(including hooking up a different amp and head unit[but using same wires]) so i think im gonna rip it all out and start from scratch on wednesday when its not so damn cold and theres not a foot of snow on the ground ..thanks again everybody ill keep you posted
Old Feb 15, 2006 | 11:56 AM
trinking's Avatar
aight so i just got everything to work..believe it or not the dam battery wire fuse blow and thats the one thing i didnt check.. i didnt check it because the amp was still getting power..turns out the amp will still get power from the battery but only half of what the battery pushes..so the system works now but the subs arent hitting very hard and the adjustments were all made on the amp already so i gotta mess with it some more.. just thought you guys might wanna know..the black rca's comin from the HU are the sub out rca's(if ya wanted to know..)
