how to connect
Old Feb 16, 2006 | 07:11 PM
WielkiWaac's Avatar
MaximaDriver
how to connect
hi.
im looking for some info how to connect everything correctly.
i want to connect my two amps to capacitor and battery.
i know its maybe easy but i have no idea how to do it.
thanks
mike
Old Feb 16, 2006 | 07:31 PM
kpr10is's Avatar
Batt+ to cap+. Cap+ to amp1+. Cap+ to amp2+. Amp1- to cap-. Amp2- to cap-. Cap- to ground.
Thats how I usually do em.
Old Feb 16, 2006 | 08:18 PM
djfrestyl's Avatar
Suspension Yoda
Throw the cap away completely cause its a bandaid and does more harm than good?
Old Feb 16, 2006 | 08:23 PM
Pearl96Max's Avatar
I tend to get a bit irritable
agreed, ditch the cap or return it and get your money back.
Old Feb 16, 2006 | 09:50 PM
maximillien's Avatar
cap is useless unless you are runnin a sub that draws alot of OHMs or current.
One way to be sure is if everytime ur sub hits and your cluster lights dims to the beat then u definitely need a cap. Other wise its useless!
Old Feb 16, 2006 | 09:52 PM
djfrestyl's Avatar
Suspension Yoda
...how does a sub DRAW ohms?
Sorry man, but instead of getting a cap if your headlights are dimming, try upgrading wire, including the big 3.
Old Feb 16, 2006 | 09:54 PM
kpr10is's Avatar
I wouldve said the same thing, but I assumed he already had it and couldn't return it. If you can return it, do so and invest in a battery and big 3.
Old Feb 16, 2006 | 09:58 PM
Pearl96Max's Avatar
Better yet he should invest in a book of basic electronics.
Old Feb 16, 2006 | 10:00 PM
Pearl96Max's Avatar
A cap is a simple bandaid, not a fix. Upgrading wiring should be the first point, others would be battery and if needed alternator. Those are resolutions, not temp fixes.
Amps do not draw Ohms, whoever told you this should lose his job IMMEDIATELY.
Thats a sure way of knowing that your car has a problem, not a way of knowing that you "need" a cap.
Old Feb 16, 2006 | 10:01 PM
djfrestyl's Avatar
Suspension Yoda
but maxmilien is the one that needs the book, and wielkiwaac needs to get rid of his cap
Old Feb 16, 2006 | 10:05 PM
Pearl96Max's Avatar
Thats who I was referring to.
Old Feb 17, 2006 | 02:54 AM
WielkiWaac's Avatar
MaximaDriver
ok guys.
i will check it out. if my lights go dim i will install cap.
if they be bright i return it to store.
thanks
Old Feb 17, 2006 | 04:06 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Originally Posted by WielkiWaac
ok guys.
thanks
that isnt what their saying. Take the cap back. When you return the cap use the refunded money to purchase yourself a high gauge wiring kit and do the big three upgrade. This will increase your ability to transfer current through your vehicle. This will reduce the dimming. Hopefully. If not then go deeper and add a battery with a little more oomph. You can use an isolated setup fi you allow yours to run with the car off like ive been known to do on occasion but a simple optima in the front is a big help. If you still need more current it is now time for you to get aholdof a high output alt. EXCESSIVE AMPERAGE owns joo there.
Old Feb 17, 2006 | 09:54 AM
djbonsu's Avatar
whats the big 3??
Old Feb 17, 2006 | 02:26 PM
djfrestyl's Avatar
Suspension Yoda
Battery - to chassis
Battery - to engine
Battery + to alternator +
Old Feb 22, 2006 | 11:55 AM
Gapp's Avatar
Chuck the cap and get an decent battery
Old Feb 22, 2006 | 01:08 PM
djfrestyl's Avatar
Suspension Yoda
Chuck Norris invented caps.
zmcneely13
Sep 26, 2015 02:26 PM
