Tool Talk
Old Mar 29, 2006 | 05:35 PM
djfrestyl's Avatar
Suspension Yoda
Tool Talk
I'm extremely bored so I wanted to get your opinions.
I was installing cold cathodes in my trunk (those fockers are bright btw) when I looked into my toolbox and noticed my soldering iron had disassembled itself again. (These tiny little screws keep unscrewing for some reason) Got p!ssed and threw it out. Now I need something to solder with, either a gun or an iron, maybe both.
What do you guys use? I've had good experiences with Weller guns.
Also, wth do all those diff tips on the iron do?
Old Mar 29, 2006 | 05:37 PM
eckounltd287's Avatar
Likes them corn fed
i'm not sure but i believe the one i have is snap on..ill check tomorrow morining...snap on rules...
nismos14's Avatar
§è~® f®ÈÄk
Radioshack gun FTW. 10 years of use still ticking.
Old Mar 29, 2006 | 05:39 PM
Likes them corn fed
wow they dont make things like they used to anymore
Old Mar 29, 2006 | 05:40 PM
Likes them corn fed
whats F.T.W
Old Mar 29, 2006 | 05:43 PM
djfrestyl's Avatar
Suspension Yoda
For The Win
djfrestyl's Avatar
Suspension Yoda
You're 18......
Old Mar 29, 2006 | 05:45 PM
Likes them corn fed
ive still delt with older material...
everythings cheap plastic now
Old Mar 29, 2006 | 06:35 PM
skierxx5556's Avatar
Yeah im using my grandfathers soldering gun its prob 30 years old and still going strong!
Old Mar 29, 2006 | 09:33 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Weller and Bluepoint here.
Old Mar 29, 2006 | 09:55 PM
slickrick's Avatar
I have prolly the same radioshack gun and it works for me...it was like $5.
Old Mar 29, 2006 | 10:55 PM
kpr10is's Avatar
If you want something simple that works fine for most things, Weller. Theres a gun that Radio Shack has though, 30 bucks, dual heat, that weighs like 5 pounds and can solder 8 gauge without a flinch. Ive had two different Wellers that are butane powered, and buying butane sucks, but wireless is fantastic. Craftsman also makes a good one, but its 60 bucks. They all die eventually though with the amount of use I give them, mainly the tips. I guess soldering guns are just one of those things that don't last.
Old Mar 29, 2006 | 11:59 PM
MrGone's Avatar
The only thing better than Snap-On is the Snap-On discount
Old Mar 30, 2006 | 12:00 AM
MrGone's Avatar
I bet that Bluepoint is a Weller
Old Mar 30, 2006 | 06:57 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
The Weller's are nice, but way too expensive for my taste. I have had my Radio Shack soldering iron for around 4 years, and it has seen ALOT of action.
My only gripe is that the tip comes loose from time to time, by that my fault due to sanding the tip as a boundary layer forms.
Weller is the way to go, but only if the work really warrants having such a high-end iron/gun. Otherwise, I recommend a 40W soldering iron from Radio Shack...
Another thing, it helps to tighten the screw before you solder...when the iron heats up, the screw expands to tighten the collar. As it cools, it may become a little loose. For the 20 seconds it takes to tighten it, I'll live.
Old Mar 30, 2006 | 08:33 AM
machinehead's Avatar
i have a walmart soldering iron, and i havent been able to solder **** with it.
Old Mar 30, 2006 | 08:35 AM
How many watts? I have used a 25W iron before, worked like ****. +40W will do juuuuust fine.
Old Mar 30, 2006 | 08:38 AM
djfrestyl's Avatar
Suspension Yoda
The one I had was adjustable through to 60w. Maybe ill just get another one
Old Mar 30, 2006 | 08:47 AM
DMCfirestar500's Avatar
I use an older Weller Gun, I think its called the expert (well older than me) for bigger stuff or soldering wires lower than 18 gauge. For the small stuff and circuit boards I have a digital adjustable Weller iron (really nice one) that a neighbor of mine sold to me for $20 a few years back (can't remember model #). With my experience with them I wouldn't go with anything other than weller unless your gonna spend alot then theres alot of good stuff out there like some of the nicer Hacko and Metcals (only 2 other high end brands I've used).
Old Mar 30, 2006 | 10:20 AM
nismos14's Avatar
§è~® f®ÈÄk
Hey did you ever sent out those LED's? I still haven't gotten them. It's been like over a month now.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
James92SE
Oct 8, 2015 04:57 PM
Colossus
Sep 9, 2015 05:46 AM
