just picked up a JL 500/1
well i seen it on craiglist, and noticed it seemed sweet
http://raleigh.craigslist.org/ele/166664999.html
it looks great, and seounds great to, i just bought his amp it was powering 2 jl w3 12's i think
i cant wait to hook it up, im trying to figure out how to wire my sub to it to get 1 ohm or the best i cant get, its a alpine type r 12 dvc, how should i wire it to get 1ohm so its 500rms??
i dont understand why the amp has 4 wire places for the sub, but its mono, idk
oh ya i got it for $200 i think its a great price????
1 DVC driver with Voice Coils in Parallel
Connecting the two voice coils of the driver in parallel (+ to +, - to -) will result in the following impedances:
Dual-6 Ohm Subwoofer: 3 Ohms
Dual-4 Ohm Subwoofer: 2 Ohms
Dual-2 Ohm Subwoofer: 1 Ohms
Dual-1.5 Ohm Subwoofer: 0.75 Ohm
im thinking this
but which outputs do i use??? thre are ++-- idk y 4
im thinking this
well i hooked it up today
and i was so suprised how great is sounded even with the gain all way down
but just a few min ago i was driving and had it not loud but up, then it just turns off and im lake damm, i thought th 60amp fuse blew,but NO my the Type r BLEW, it sucks, ive never had this much power and cant controll it.
idk what to get but i kinda want a single 15, i might get the new style type r and controll my self
12 myne was the old type and a pos to start with
yes im comming from a sony xplode 600w, lol im use to full volume with no problems at all
so a new style type r 12 should be ok?? i had myne in a parallel, should i wire it different???
ah then I understand I have seen 3 type r 12's blow with around that much power. I would get a nice 12 or 15. IIRC that amp does power from 1.5-4 ohms and if you have a dvc2 12 (which I doubt) then I'm surprised the amp ran well. anyway, look to achieve a 2 ohm load with any sub setup and you are fine.
wow i use to think it was a stout sub, guess not
myne was DVC 4ohm, i think i had t wired so ir was running at 2 ohm
i might buy a type r for cheep for now and try to not blow it, or ill go to a deler around here and get a real sub
Now for some better advice. Find out at what impedence your amp put out the most safe clean power at and then match your subs accordingly. In the case of the JL 500/1 it really does not matter as long as it is 1.5-4 ohms as will put out the same amount of power over that range.
Rick
Originally Posted by SQMaxima
That statement is not a good basis, or even a general statement. Shoot, still more then 90% of todays 2 channel amps CAN NOT run 2 ohms bridged and you would end up frying the amp with that advice. Also about half of todays 1 channel D-class amps can produce way more power running down to 1 ohm so on that advice you would be wasting half the amps power.
Rick
Rick
I thought those amps put out full power at anywere between 1-4 ohms. I could be mistaken and that could be only th 1000/1. If that is the case, it doesnt really matter how you wire it once you dont go beloiw 1 ohm and set the gains correctly, preferebly with a 50 Hz tone.
http://mobile.jlaudio.com/products_amps.php?amp_id=252
http://mobile.jlaudio.com/products_amps.php?amp_id=221
incorrect on both accounts.
Pied
Sep 26, 2015 03:29 PM
