(More) Bose Issues
Old Aug 30, 2006 | 08:29 AM
MaximaBoy04's Avatar
on the G coupe bandwagon
(More) Bose Issues
Hey All,
I've Browsed/searched the forums and I feel like this is a common problem. My main issue is removing the dash, I've seen multiple threads on it but most link to a site where you have to pay to see pics of removal? I don't think so. All I need to know is how exactly do you get the area around the AC vents out? I tried a flathead screw driver and a butter knife and had to stop because I was convinced something was about to break.
I'm running a '97 max with the Bose audio system. The front passenger speaker fades in it out, usually fading out when I am accelerating or taking a hard turn, also over bumps sometimes. I've found that if I tap on it forcefully or push on it on the right side the speaker's clarity will sometimes improve. I figure if I pop the dash and take a look around I might get lucky and find something loose, and not bother having to take it in.
Any thoughts or suggestions?
Old Aug 30, 2006 | 11:17 AM
nismos14's Avatar
§è~® f®ÈÄk
Pop the bottom of the piece with the clock out with a knife or flat head then pull it straight out towards you, the clips will give eventually then its pretty easy from tehere.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
Maxima Pride '07
Sep 12, 2015 07:29 AM
popdedop
Sep 11, 2015 11:17 AM
