wire plucking (e-blue)
Old Sep 14, 2006 | 05:51 AM
MDeezy's Avatar
Maybe it’s just me, maybe its not. I am trying to remove some of the wires from in the harness of the E-Manage blue, but was unsuccessful. It wasn’t as easy and tugging on the wires and they pop out. Does anyone know how I can pull these wires out, I will need to add/remove so that I can get extra functionality from my . . . non rev-limiter adjusting, can only data log timing. E-manage . . .blue
Thanks.
Old Sep 14, 2006 | 02:01 PM
djfrestyl's Avatar
Suspension Yoda
Pics would help a bit. Where are you pulling them out of?
Old Sep 14, 2006 | 03:45 PM
RA030726's Avatar
I'm nutty for Nissans
You can usually use a pick tool and stick it into the connector from the back side. Youll have to compress the metal part that sticks up and holds the wire in.
Old Sep 14, 2006 | 05:21 PM
MDeezy's Avatar
Here is a picture to get a better idea of what I'm trying to do. Trying to remove the wires from the back of the harness. I will need to remove and add. I assume the process is relatively the same.
I search around for a pick tool. I did a couple google/yahoo searches and didnt pop up much on a pick tool. Does it go by a different name? or do you have a pic of one or know where I can get one.
After speaking with greddy I can add wires into the harness and they will work fine. Good way to save and have the extra options of logging fuel and timing.
Old Sep 14, 2006 | 06:44 PM
djfrestyl's Avatar
Suspension Yoda
You can get a set of 4 different picks from Sears for like 7.99
One's straight, one's a right angle, another is a hook, and the other is just, offset and weird shaped.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
