dumb question: which wire is the ground on the wire harness?
Ok, this might seem dumb, but I've bought 3 different wire harnesses and none of them have a solid black (ground) wire on them. The last one I bought was the Metra 70-7550 from Crutchfield. The only "ground" on it is the "amplifier shield ground" on the smaller plug. Is this what I should be using? I have included a link where I scanned the sheet that came with it. The reason I'm so concerned is I need a ground to disable the parking brake sensor on my Kenwood DDX6019.
http://members.***.net/wope/wh.jpg
Thanks alot
Thanks alot
Jitiola, do not post misinformation that will only confuse people and cause more newb-like threads, no offense to wope.
Wope, disregard the above post, and like I said, simply screw your ground to bare metal.
Originally Posted by nismos14
Definately ground it to the chassis somewhere forget grounding it to the harness as you'll get a better ground from the chassis anyways.
Chassis will give you A ground. Harness doesnt have one at all.
