JL subs not performing the way they should, HELP!
Old Oct 16, 2006 | 07:52 AM
Gian13's Avatar
Went to best buy and after they charged me $220 for installing a JL Prowedge 2 10" subs with a JL e2150 amp that I already had the sound is very poor.
Sounds as loud as the OEM subwoofer. I can;t even tell I have the setup in the trunk.
I had this setup installed in a 2003 Eclipse and the setup sounded 10 times better. What do you think the problem could be?
I'm illiterate on car electronics stuff, that's why I didn't even try doing it myself.
I also have a PAC converter that I bought on ebay for like 50 bucks that I thought he was going to need but the "technician" said he was not going to need it.
Old Oct 16, 2006 | 09:27 AM
djfrestyl's Avatar
Suspension Yoda
Bose or non-bose? Where did he get the signal from?
Old Oct 16, 2006 | 09:41 AM
Gian13's Avatar
Yeah OEM Bose HU
Old Oct 16, 2006 | 09:42 AM
djfrestyl's Avatar
Suspension Yoda
Alright, what did the tech use to get signal? Did you check your amp settings? Try turning the gain up on the amp, but not too much
Old Oct 16, 2006 | 10:15 AM
nismopc's Avatar
Seems to me they got you good...
...like $100+ an hour labor???
Old Oct 16, 2006 | 04:12 PM
BLK2BLU's Avatar
wow...someone doesnt know what they are doing. I would take it back and get them to check the ohms or something.
Old Oct 16, 2006 | 04:51 PM
myer84's Avatar
I would go back and kick them in the nutz. And have a real pro check it out
Old Oct 16, 2006 | 05:38 PM
Batxel's Avatar
blah
Is this the same exact setup you already had?
If so diy next time and check the wires. Also, put in consideration that there are two different body styles. You usually get a better SPL response in a 2 door hatch vs a 4 door w/ trunk.
Old Oct 19, 2006 | 05:49 AM
Gian13's Avatar
Just came back from best buy, the tech guy took a look at what the Saturday's tech did and found the problem. Apparently he connected the amp to the input of the converter instead of the output. Problem fixed!
Now the damn thing is too loud even at -5 Bass in the Bose HU. I guess I need to tune it down a little. I'll play with the amp settings tomorrow.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
Dasmith
Sep 23, 2015 08:28 PM
