how are you guys splicing wires for keyless entry/remote start
Old Oct 22, 2006 | 08:53 PM
Sevorg1's Avatar
I was just curious what method you guys have used for splicing wires when installing remote starts/alarms/keyless entry. are you cutting wire then using the little wire caps that you crimp back, or have you guys used the little sleeves that crimp at both ends, or are you guys just twisting wires and using electrical tape (I hope not......seen it done though) what is yall's method?
I'm thinking about buying a remote start and installing one, but I have not done one before, so I'm nervous about fuggin it up. I can install car stereos and I am knowledgeable about electrical systems, and know how to use a multimeter.
Old Oct 22, 2006 | 08:57 PM
DcMaN's Avatar
wire strippers + xacto knife ftw
Old Oct 22, 2006 | 09:42 PM
kpr10is's Avatar
Being that Im required to solder every connection for work...
For thicker wire, aka ignition harnesses
For thin wire
http://buy1.snapon.com/catalog/item....store&tool=all
Old Oct 23, 2006 | 10:08 PM
Midwest Kid's Avatar
For thin wire
PIA but its so much more reliable and safer. BTW, i found all the triggers. To bad an 04 doesnt have more than a 40 pin connector at the BCM. I dont know what the hell is up with the diagrams. Oh well, It was nice pulling the trunk trigger, door triggers, trunk release, both CAN wires and lock data wire from the same location.
Old Oct 24, 2006 | 02:46 PM
Sevorg1's Avatar
no one really answered my question about what kind of crimping method they use. sodering doesnt count
Old Oct 24, 2006 | 03:07 PM
DcMaN's Avatar
crimping ftl on ignition wires. Most people use t taps i guess. Not exactly the safest on high current/large gauge wire imo.
Old Oct 24, 2006 | 03:16 PM
Sevorg1's Avatar
ftl? t taps? what are they? thats why I dont know what is going on I dont know what ftl is
Old Oct 24, 2006 | 03:28 PM
mendon99's Avatar
tastey wheat
ftl is for the lose. this is a T-Tap:
It's on the left there.
and to crimp them, i use snap-on battery terminal pliers. they work like they were meant to do the job..
Old Oct 24, 2006 | 06:45 PM
-Sin-'s Avatar
Strip the wire but not cut it, then thread the other wire through, twist the threaded wire around the original then solder.
maxipower
Aug 21, 2015 11:10 AM
beboski
Aug 16, 2015 05:23 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
Blackwind
Aug 5, 2015 06:35 PM
