Difference of Preamp Output Volts
Old Nov 26, 2006 | 11:42 AM
Hunter11's Avatar
I am planning on getting a new head unit. My old one had 5V preamp outputs. Some of the ones I am looking at now have 2.5V to 4V.
What difference am I looking at when it comes to sound? Is there a huge difference from the 5V to the 2.5V?
Old Nov 26, 2006 | 03:09 PM
mendon99's Avatar
tastey wheat
meh, big difference? it'll make a difference. it will be a bit louder, and some argue that the higher the preout voltage, the cleaner the signal, but im not sure if its been proven..
Old Nov 26, 2006 | 04:37 PM
Hunter11's Avatar
I figured it would make the bass less distorted and more precise but didn't know if it would be a noticable difference.
So it shouldn't make or break weather I buy a certain hu?
Old Nov 26, 2006 | 06:38 PM
nismos14's Avatar
§è~® f®ÈÄk
It is definately a noticeable difference. A signal in the 2v range powering say a stock oem amped system vs a 5v signal powering the same stock amped system makes a huge difference in output.
If you are designing a system from scratch it would be best to get a unit that best suits the demands of your amplifiers. Some amps require a higher signal to reach their correct output level effectively. With a lower signal you may find yourself turning the gains past 3/4s when they could be at 1/4 with the higher voltage hu.
Old Nov 26, 2006 | 07:29 PM
Hunter11's Avatar
I didn't even think of what the amp needed. I see what you mean with the amp gain. I will have to go see what the gain is on now. I haven't touched it since I had the 5V hu in there.
Old Nov 26, 2006 | 07:59 PM
nismos14's Avatar
§è~® f®ÈÄk
It shouldn't pose a problem, but you shoud notice higher volume levels at lower volume settings on the HU with a higher voltage HU vs a lower voltage HU.
Old Nov 27, 2006 | 04:49 AM
mendon99's Avatar
tastey wheat
yeah . thats what i was trying to muster up, i was just too tired last night.
the higher the preout voltage the better.
Old Nov 27, 2006 | 02:10 PM
Hexon's Avatar
I am hopefully getting the eclipse3000 for xmas. It has 5v output. because it might be louder at lower volume levels than my stock HU, could I turn the volume up more without worrying about busting my speakers?
Old Nov 27, 2006 | 02:15 PM
mendon99's Avatar
tastey wheat
if you add an external amp and its tuned properly, then yes. but if not, you'll get distortion at some point, its inevitable (it'll be at a louder level than stock tho, probably).
Old Nov 27, 2006 | 02:20 PM
Hexon's Avatar
I am just always afraid to blast my stereo with my stock HU. I don't want to worry about blowing my speakers. I would just like to be able to turn it up a little more.
Old Nov 28, 2006 | 04:40 AM
bigmike8771's Avatar
if you really wanna step up the voltage the eclipse 5000 has 8V outputs, that will really help your system, most amps can handle a 8v input, but make sure yours can if you decide on that particular HU, and good luck with your system...
Old Nov 28, 2006 | 01:00 PM
Hexon's Avatar
haha, yeah but if i got the 5000, that's all I would probably get cause my parents aren't spending as much this year b/c we are going on a ski trip to Colorado. I have to have clothes to wear while im there haha.
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
