I'm bringin sexy back..
Old Dec 10, 2006 | 08:38 PM
Pearl96Max's Avatar
I tend to get a bit irritable
..in Black...
Old Dec 10, 2006 | 08:40 PM
filtor1's Avatar
Oh really? Are they for you?
Old Dec 10, 2006 | 08:46 PM
Pearl96Max's Avatar
Maybe for the wifeys car....
BUT..I dare ya to find someone else in the country with them.
Old Dec 10, 2006 | 08:50 PM
Pearl96Max's Avatar
Specs..
600.1
Power @ 4 ohm: 200x1 HP Filter Range: 15-55 Hz @ 24 dB/oct
2 ohm: 400x1 LP Filter Range: 30-300 Hz @ 24 dB/oct
1 ohm: 600x1 Bass Boost: 0-18 dB @ 45 Hz
Sensitivity: 200 mV to 8V Min Load Imp: 1 ohm
Damping: >200 Pwr/Gnd Wire: 8 AWG
Distortion: < 0.1% THD Rec Fuse: 50A
S/N Ratio: >90 dB Bass control mount included
Dimensions: 273W x 250L x 61H (mm)
10.75W x 10L x 2.4H (in)
300.4
Power @ 4 ohm: 50x4 HP Filter Range: 20-400 Hz @ 12 dB/oct
2 ohm: 75x4 LP Filter Range: 40-400 Hz @ 12 dB/oct
Sensitivity: 200 mV to 8V Bass Boost: 0-18 dB @ 45 Hz
Distortion: < 0.1% THD Min Load Imp: 2 ohm Stereo / 4 ohm Bridged
S/N Ratio: >110 dB Pwr/Gnd Wire: 8 AWG
Dimensions: 273W x 320L x 61H (mm) Rec Fuse: 50A
10.75W x 12.6L x 2.4H (in)
Old Dec 10, 2006 | 08:51 PM
Pearl96Max's Avatar
Looks purdy when lit up...
Old Dec 10, 2006 | 08:59 PM
filtor1's Avatar
They look great. Wall off the van?
Old Dec 10, 2006 | 09:01 PM
Pearl96Max's Avatar
ummm nut uh
Old Dec 10, 2006 | 09:31 PM
mendon99's Avatar
tastey wheat
wow, didnt know alumapro made amps..
shweet
the gain **** seems to be off center..
Old Dec 10, 2006 | 09:38 PM
Pearl96Max's Avatar
They do now.
It might be, or could be my picture taking skills..
Old Dec 11, 2006 | 06:47 AM
MacAlert's Avatar
Originally Posted by Pearl96Max
They do now.
I would go with the later.....
Umm, you were complaining about no room in the trunk of the G and you want to put an amp in the van now?!
Old Dec 11, 2006 | 07:09 AM
Pearl96Max's Avatar
Sure why not? Theyre small enough to go under the seat.
Old Dec 11, 2006 | 07:13 AM
KUBLKMAX's Avatar
not bad lookin at all. actually the all balack is pure sex
Old Dec 11, 2006 | 07:19 AM
MacAlert's Avatar
Hope you fix that alarm problem while your in there.
Old Dec 11, 2006 | 12:59 PM
nismos14's Avatar
§è~® f®ÈÄk
They look good, now I wonder how they sound.
Old Dec 11, 2006 | 02:21 PM
djfrestyl's Avatar
Suspension Yoda
They ended up looking good. Had no idea they were going to be black..looks real classy. Who's the lucky buyer?
iflexsteel
Sep 2, 2015 08:04 AM
Jeff2k1GLE
May 25, 2001 04:09 PM
