Speaker vs. Amp problem?
Old Jan 23, 2007 | 08:50 AM
Bham Max's Avatar
I have a problem with one rear OEM speaker. How can I tell whether it is a blown speaker or a problem with the amp for that speaker?
Old Jan 23, 2007 | 08:51 AM
slickrick's Avatar
By explaining the problem more in depth...
Old Jan 23, 2007 | 09:33 AM
Bham Max's Avatar
Here's the details: Replaced OEM HU with another used OEM HU and upon checking functionality of balance & fade discovered garbled noise coming from driver side rear speaker. I'm not an audio guy, but understand that the Bose speakers are individually amplified. Wondering whether I need to replace the speaker, the amp, or both - and how to tell the difference.
Again, thanks.
Old Jan 23, 2007 | 09:53 AM
nismos14's Avatar
§è~® f®ÈÄk
Actually, in your car, they are amplified by one single amplifier.
Old Jan 23, 2007 | 01:17 PM
Bham Max's Avatar
so, I take it that since the other speakers are fine, the amp is fine, so it must be a blown speaker and I need to replace the speaker, no?
Thanks for the help!
Old Jan 23, 2007 | 01:56 PM
AscendantMax's Avatar
well, if you have a multimeter handy you can check the resistance of the speaker to see if it's still ok. take the two leads from the multimeter and touch it to the terminals on the speaker. i forgot whats the load, but if i recall it's somewhere around 1 ohm.
Old Jan 23, 2007 | 07:02 PM
Bham Max's Avatar
so, per your recommendation, if I check the resistance of the speaker (while stereo operating I presume) and I see appropriate reading (1-2 Ohm, right?), then that tells me that the Amp is OK - sending appropriate signal to speaker - but speaker is blown?
I was figuring one thing I can do is attach any speaker to the lead for long enough to check and see that the amp is working ok. It won't be 2 Ohm speaker, but if I get sound (at lower volume, I know), that should indicate that the Amp is OK and it's a speaker problem, wouldn't it?
Old Jan 23, 2007 | 07:08 PM
nismos14's Avatar
§è~® f®ÈÄk
No apply it to the speaker with the stereo off. Then you can attached a second speaker to test if it works.
Old Jan 23, 2007 | 07:24 PM
do it with the stereo off.
but if the resistance of the speaker checks out, more than likely it's the amp's (or that HU you just swapped in) fault.
Mar 12, 2020 12:06 AM
Excalibur23
Oct 13, 2015 04:33 PM
popdedop
Sep 11, 2015 11:17 AM
videomano
Sep 8, 2015 03:28 PM
