View Poll Results: What kinda box you got?
Voters: 45. You may not vote on this poll
Ported sealed or bandpass?
Nope, picked that one up from a buddy. Not tuned right for the SP12, but tuned PERFECTLY for my HX2. Well I actually did the tuning with the port, but the internal volume was too much for the SP12, but just right for the HX2.
and you wonder why it doesnt sound 'right' ? Ported/vented enclosures are not nearly as forgiving as sealed...
Yes it was boomy. The box was 1.88 after sub and port displacement and tuned to 30 hz. I have box coming that is built to spec, and if the dls doesn't sound good in that I'll be pissed lol. I'm aware of that Don! But I figured it would be a little more forgiving, at least I have the perfect sized/tuned enclosure for my HX2
Originally Posted by slickrick
Man I've said this many time to Manny, but how do you bums get that nice carpet in the trunk? My max came with the same crap carpet that lines the trunk. how's that setup sound in the max?
They actually clean their carpet maybe thats why................. lol jk
Brendon, the new box is gonna be built to SP12 specs.
sounds great! i'll let parag give a review of it after this weekend.
just work one panal at a time. put the carpet on a big table. then spray glue on both the carpet and box. remember to have some overlap on the sides. wait a few seconds for the glue to get tacky...then roll the box onto the carpet. the weight of the box will help with the adhesion. then keep spraying and rolling until the entire box is covered. then take the over lap and fold like a letter...then take a SHARP razor and cut diagonally from one corner to the other. you basically cut an "X" on the side. the excess carpet will come off leaving you with 4 flaps that will meet in the middle.
then just cut out the sub hole and what not with a razor.
eh...maybe "letter" was a bad choice of word...
lemme find that thread on ca.com. it got pics and what not on how to carpet. but it's really easy. i carpeted the box i made for my cousin (ported for 2 tens) in 15 mins.
use tacky spray glue. make sure you read the directions on how to use the glue properly before you start. otherwise the carpet'll fall off.. Done properly, you wont need to use 1 staple.
the glue i used, i had to wait till it was completely dry on both sides, then it would stick. if it was wet still, it wouldnt work, not sure if this is how it is with all the spray glues
but it holds very well.
Originally Posted by burnurass
3M™ Super 77 Multipurpose Adhesive 7706
i used that on my bezel and amp rack...it sticks nice and it's quick
early ported
early sealed
the product-Turns out four took up too much room lol
a couple in the middle but i like this one
