AVIC D3 installed in my 6th gen...
Old Apr 9, 2007 | 12:39 PM
jsmithsole's Avatar
*moderator*
This unit is great, I upgrade from the N2 to this. Love the double DIN now and the IPOD controls made it all worth it!!
Old Apr 9, 2007 | 12:40 PM
nismos14's Avatar
§è~® f®ÈÄk
Wait did you hook up the camera to the screen on top? It looks hot btw.
Old Apr 9, 2007 | 12:42 PM
jsmithsole's Avatar
*moderator*
I hooked the camera up to the screen up top through an RCA switch so I can flip it see video from the HU or leave the rear view on full time...
And thanks!!!
Old Apr 9, 2007 | 12:45 PM
danger300z's Avatar
congrats sweet set up.
Old Apr 9, 2007 | 07:09 PM
jsmithsole's Avatar
*moderator*
Thanks, Im liking the D3 more and more!
Old Apr 9, 2007 | 07:59 PM
mendon99's Avatar
tastey wheat
looks good man, what kit is that?
Old Apr 10, 2007 | 12:19 AM
jsmithsole's Avatar
*moderator*
Sorry, what kit are you referring to...dash kit, body kit?
Old Apr 10, 2007 | 01:36 AM
dans04max's Avatar
What wire is the VSS wire on 6th gen Maxima's? I am installing a AVIC-D1 and need to find the VSS wire.
Old Apr 10, 2007 | 04:31 AM
mendon99's Avatar
tastey wheat
the dash kit, sorry.
Old Apr 10, 2007 | 09:24 AM
jsmithsole's Avatar
*moderator*
It's the Metra kit, you can find them on EBAY...
Old Apr 10, 2007 | 04:03 PM
djfrestyl's Avatar
Suspension Yoda
That's a whole 'lotta screenage. Nice job.
Old Apr 10, 2007 | 08:14 PM
jsmithsole's Avatar
*moderator*
Don't forget 2 more in the headrests!!!
Old Apr 10, 2007 | 08:57 PM
AscendantMax's Avatar
Mmmmm, looks nice!
is that the standard metra kit with the central pocket clipped off?
Old Apr 11, 2007 | 07:55 AM
jsmithsole's Avatar
*moderator*
Originally Posted by AscendantMax
Mmmmm, looks nice!
It sure is!!
Old Apr 11, 2007 | 07:56 AM
UnMaTcHeD's Avatar
Not for rookies!!
Looks good man, does the d3 have dual zone listening?
Old Apr 11, 2007 | 09:41 AM
jsmithsole's Avatar
*moderator*
No, the only drawback so far. Never even checked as I didn't think they'd remove this feature...
Old Apr 11, 2007 | 09:45 AM
nismos14's Avatar
§è~® f®ÈÄk
And single disc input.
Old Apr 11, 2007 | 11:45 AM
UnMaTcHeD's Avatar
Not for rookies!!
Your n2 did, right?
Old Apr 11, 2007 | 12:42 PM
jsmithsole's Avatar
*moderator*
Yeah but I had the single disc on my N2, so no change there for me.
And yes the N2 had multi zone...
Old Apr 11, 2007 | 07:08 PM
dans04max's Avatar
Can anyone please tell me where the VSS wire is on a '04 Maxima SE w/out Bose?
I REALLY NEED YOUR GUYS HELP!
Old Apr 11, 2007 | 07:15 PM
djfrestyl's Avatar
Suspension Yoda
NISSAN, MAXIMA, 2004, Speed Sense
Green or brown wire
Unified Meter and A/C Amp, pin 26
Note:
The Unified Meter and A/C Amp is the first module below the display in the dash.
That's all I've got.
Old Apr 11, 2007 | 07:26 PM
Ankit69's Avatar
damn jsmith 8000+ songs, i knew you were a led ***** but didnt know you were a music ***** too
Old Apr 11, 2007 | 07:47 PM
ridin.i35's Avatar
8000 songs... whats that, the 80gb ipods?
Old Apr 11, 2007 | 09:13 PM
jsmithsole's Avatar
*moderator*
Yes I have quite a mix of music, my work has a music server where you can pull other poeple's music off their Itunes. It's easy to load up...
(and it's a 60gb with plenty of room left)
I only have a few movies and videos on there now with this setup I need to get moving on those!
Old Apr 11, 2007 | 09:17 PM
Ankit69's Avatar
cool cool... how hard is it to scroll through ur music, is there a loading time, i have the z1 and thats the only part i dont like about it...
Old Apr 12, 2007 | 05:57 AM
jsmithsole's Avatar
*moderator*
No it is very quick, scrolling through is a bit harder than it should be though. Not sure how the interface on the Z1 is but this one is pretty user friendly...
Old Apr 12, 2007 | 09:14 AM
dans04max's Avatar
Thank You So Much Djfrestyl!
Old Apr 12, 2007 | 01:08 PM
jsmithsole's Avatar
*moderator*
There's this too (in the stickies )
Speed Sense green or brown 8P Unified Meter and A/C
Amp, pin 26
http://forums.maxima.org/showpost.ph...75&postcount=1
Diagram for '05, but should be same for '04 and maybe '06. Source of diagram is good. However...
Attempt at your own risk.
Nissan Maxima 2005
12volts green (40A) + ignition harness
Starter black/red + ignition harness
Second Starter black/yellow + ignition harness
Ignition black/red + ignition harness
Accessory red + ignition harness
Second Accessory white/blue + ignition harness
Keysense black/red + ignition harness or
BCM, pin 37
Notes: The BCM (Body Control Module) is between the steering column and the fuse box.
Power Lock blue or pink/blue - driver door module in
door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock red (double pulse) - driver door module in
door
Lock Motor gray 5wi BCM, pin 50
Unlock Motor green 5wi BCM, pin 44
Disarm Defeat green/yellow 5wi BCM, pin 51
Parking Lights+ red/blue + driver kick, harness to
rear
Parking Lights- N/A
Hazards green/red - BCM, pin 29
Turn Signal(L) green/black + BCM, pin 45
Turn Signal(R) green/yellow + BCM, pin 46
Headlight blue (L), red/yellow (R) + IPDM E/R, pins 30 and
20
Notes: The IPDM E/R (Intelligent Power Distribution Module Engine Room) is behind the
passenger side headlight. All the wires are in a gray 16 pin plug.
Reverse Light green/white + driver kick, harness to
rear
Door Trigger see notes - BCM
Notes: The LF door is lt. blue in pin 62, the RF door is brown/white in pin 12, the LR door is
red/black in pin 63, and the RR door is blue/red in pin 13. Use all four wires and diode isolate each.
Dome Supervision red - BCM, pin 48
Trunk/Hatch Pin purple/white - BCM, pin 57
Hood Pin N/A
Trunk/Hatch Release blue or blue/white - BCM, pin 30
Notes: The BCM (Body Control Module) is between the steering column and the fuse box. The fuel
door release is green in the driver kick, in the harness to the rear. It is a high current negative wire.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power
unlock wire
Tachometer NOT red or black ac any ignition coil or fuel
injector
Wait to start N/A
Amp, pin 26
Notes: The Unified Meter and A/C Amp is the first module below the display in the dash.
Brake Wire red/green + brake pedal switch
Parking Brake pink/black - parking brake switch
Horn Trigger green/white - horn switch
Wipers blue (L), blue/black (H) + IPDM E/R, pins 21 and
31
LF Window up/dn see notes
Notes: Extended triggers on the lock/unlock wires will roll the windows up/down. Use validity
channels to control.
RF Window up/dn see LF window up/dn
notes
LR Window up/dn see LF window up/dn
notes
RR Window up/dn see LF window up/dn
notes
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
Memory Seat 1 blue/white - ADP Control Unit, pin 9
Notes: The ADP (Automatic Drive Positioner) control unit is the second module below the display in
the dash.
Memory Seat 2 purple - ADP Control Unit, pin
25
the dash.
Memory Seat 3 N/A
Radio 12v yellow + radio harness
Radio Ground (chassis)
Radio Ignition purple + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/white + radio harness
Power Antenna green/white + radio harness
LF Speaker +/- white - black +,- radio harness
Notes: The BOSE speaker amp is under the rear deck. The speaker wiring at the amplifier is: LF
blue/white - blue/black, RF white/black - green/black, LR green/yellow - blue/yellow, and RR blue -
red.
RF Speaker +/- yellow - brown +,- radio harness
LR Speaker +/- green/yellow -
black/yellow
+,- radio harness
RR Speaker +/- blue - red +,- radio harness
Immobilizer Bypass
Module:
Required: Yes Type: Transponder Part #: 556UW
Notes: Standard on all models.
It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Old Apr 12, 2007 | 02:22 PM
rrj72's Avatar
sick!
that looks clean for having two monitors in the dash, I'm guessing the 3rd one on the bottom is factory?
Old Apr 13, 2007 | 11:09 PM
jsmithsole's Avatar
*moderator*
Yes I moved it from the top down to the bottom...
Old Apr 13, 2007 | 11:15 PM
always did want to change out all the LEDs on our center dash to white...instead of that burnt orange color. but i can't force myself to fork out the money for that big LED swap kit.
Old Apr 13, 2007 | 11:37 PM
jsmithsole's Avatar
*moderator*
It's alot of money but by far the BEST mod I think I have done to my entire car!!
Old Apr 14, 2007 | 04:50 PM
dans04max's Avatar
Hey guys, I tried the green wire(s) on the big white connector on the unit just below the screen and it did not work on my AVIC-D1. Can anyone please just tell me exactly what one is the VSS wire on the 3 connectors just below the screen? Thanks
Old Apr 14, 2007 | 05:52 PM
nismos14's Avatar
§è~® f®ÈÄk
SHould be the pink wire, not the GREEN with WHITE. Green with white is for the reverse.
Old Apr 15, 2007 | 11:38 AM
Stealth Max's Avatar
Wow another nice set up for the Maxima! How do you like the D3 over the N2?
Old Apr 15, 2007 | 12:49 PM
jsmithsole's Avatar
*moderator*
The D3 prefails for sure just the IPOD and XM controls are worth the upgrade. I am missing the dual zone, external display of NAV and the screen tilt though!!
Old Apr 15, 2007 | 05:16 PM
dans04max's Avatar
There are three connectors that goto the Unified Meter and A/C Amp. . .2 grey and 1 white connectors. The two grey connectors are labeled AMP so I am guessing they are to the A/C Amp. On the WHITE connector I have tried both green wires (One with a black stripe on it and the other is a lime green color) w/NO LUCK! There is no brown wire! I have also tried other wires with no luck (Blue with black etc.). I REALLY NEED HELP ON GETTING THE VSS WIRE ON A 2004 MAXIMA w/NO BOSE! Please anyone preferably someone who has installed a AVIC-D1 etc. in their own 2004 Maxima and got the right VSS wire. I need to know this ASAP. Thanks everyone!
-Joe
Old Apr 15, 2007 | 05:56 PM
nismos14's Avatar
§è~® f®ÈÄk
VSS should be PINK not green.
Old Apr 15, 2007 | 06:22 PM
dans04max's Avatar
There is no pink wire at all in the back of the A/C Amp and Unified Meter!
jsmithsole. . .what wire did you hook up your VSS pink wire to on your stock wiring?!
Old Apr 15, 2007 | 06:42 PM
nismos14's Avatar
§è~® f®ÈÄk
Behind the cluster.
